VideoHelp.com Forum
    I'm using DVDFab Decrypter. I select the source and target then click the start button. Everytime it hangs (no DVD activity). I'm currently using version 2.9.2.2. However the same thing happened with the previous versions. I'm using a NEC 2510A and W2K with the latest patch. Any ideas. Thank you in advance.
  2. VH Veteran jimmalenko's Avatar
    May be something to do with your ASPI layer. Either that or the program just doesn't like something with your set up. As alternatives, try DVDDecrypter (if you can find it) or smartripper.
    If in doubt, Google it.
  1. DVDFab 7 HD Decrypter
    By burnmaster in forum Blu-ray Ripping
    Last Post: 9th Apr 2010, 08:11
  2. DVDFab Decrypter
    By HacktheHacker in forum DVD Ripping
    Last Post: 25th Feb 2008, 23:10
  3. DVDFab HD Decrypter Issue
    By adcmarti in forum DVD Ripping
    Last Post: 27th Sep 2007, 23:24
  4. DVDFab HD Decrypter???
    By bltprf in forum Newbie / General discussions
    Last Post: 9th Jul 2007, 00:09
  5. problem with DVDFab Decrypter
    By cmonzon in forum DVD Ripping
    Last Post: 4th Jul 2007, 20:18
