I've got a weird problem to do with the power/turning on/off the dvd recorder.
Sometimes to get it to work, I have to unplug it from the back, wait for it to say "POWER OFF" on the display. and then keep on pressing the power button on the front of the player, until it switches on. If I can get it switched on though, the fan at the back kicks in and everything is fine.
The main problem comes when turning of the unit.
The fan stops, and the clock display comes on, now sometimes after a while, the fan comes back on with the unit on standby. When you try and turn it back on, it wont, the fan is still on even though the unit is on standby, and the clock seems to stop completely, meaning the box has obviously crashed.
This is really bugging me at the moment, when it seems to freeze, if you press and hold the power button for a certain length of time, you get 5 beeps, and the player seems to reset itself. After doing this though, it STILL will not turn on without continuly pressing it after resetting it.
Anyone else had this problem? How can I fix it?
Results 1 to 1 of 1
Thread: Sony RDR-GX3 Power Problem
Sony RDR-HX720 problem with divx
By giltic in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Apr 2009, 13:07 -
Sony RDR-HX715 and TV Guide - recent problem?
By bjl_avs in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2009, 10:42 -
Sony RDR-VX525 Capture Problem
By Aviator327 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 18th Apr 2008, 06:07 -
Sony RDR GX 330 problem with recording signal?
By rjl24 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Mar 2008, 07:58 -
Sony GX3 Motion Trail
By fubsy in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Oct 2007, 11:12
