VideoHelp.com Forum
  1. Everytime i try to convert from DVD to Xvid i get an error when I'm about to encode. It says "Stats File not found". Converting to Divx works just fine, but I'd rather have Xvid for some of the DVD's im backing up. I've been following the guides exactly.
    EDIT: One more thing... Whenever i use AutoGK i set the file to around 175mb and it ends up 110mb. And its causing me a little loss in quality. How can i fix that?
  2. Hi-
    Maybe a couple of reasons for that. One might be that you didn't run the first pass. In XviD Configuration->Encoding Type, make sure it's first set for "Twopass-1st Pass. Then hit the "More" button and scroll to the place you want to keep the stats file (nowadays it's a .pass file), and give it a name, "Movie.pass".
    The other reason might be that you really did run the first pass, changed to "Twopass-2nd pass", but you hadn't saved the first pass Movie.pass file correctly. Make sure it has the ".pass" as an extension.
    Kind of hard to know what happened unless you post the log. There's always the chance that you maxed out the quality. You might check the log to see if the compress test result was over 100%. If so, it can't get any larger than what you got with the settings you chose. You might try giving it a higher resolution, or better audio (AC3 instead of MP3, for example).
  3. Member KneeGrow's Avatar
    manono, thanks for this one, I was really wrestling with this!
    And yes, imho, it was worth rekindling a 14 year old thread....
    I stored mine in the same folder as the movie files and called it movie.log, this can also be called movie.pass
    Also for this:
    An example of such a notorious Virtualdub XviD stats file (and this for a video clip of JUST 137 frames!!):
    # XviD 2pass stat file (core version 1.1.2)
    # Please do not modify this file
    i 2 1053 0 0 3076 3076
    i 2 1053 0 0 37933 3787
    b 4 0 1053 0 2973 1326
    p 2 18 944 91 16771 1959
    b 4 0 1053 0 2899 1287
    p 2 10 958 85 13418 2008
    b 4 0 1053 0 2771 1242
    p 2 13 951 89 15977 2058
    b 4 0 1053 0 2651 1125
    p 2 9 935 109 13805 1924
    b 4 0 1053 0 2745 1055
    p 2 4 928 121 14545 1819
    b 4 0 1053 0 2515 1058
    p 2 4 923 126 15269 1857
    b 4 0 1053 0 2789 1148
    p 2 4 933 116 14054 1803
    b 4 0 1053 0 2939 1169
    p 2 1 928 124 16248 1872
    b 4 0 1053 0 3120 1276
    p 2 7 915 131 17484 1885
    b 4 0 1053 0 3358 1160
    p 2 3 917 133 15630 1831
    b 4 0 1053 0 3138 1207
    p 2 2 930 121 15766 1794
    b 4 0 1053 0 3372 1409
    p 2 2 923 128 15753 1832
    b 4 0 1053 0 3342 1402
    p 2 7 912 134 15079 1770
    b 4 0 1053 0 3007 1401
    p 2 6 913 134 14958 1821
    b 4 0 1053 0 3500 1615
    p 2 7 915 131 15636 1877
    b 4 0 1053 0 2689 1334
    p 2 9 919 125 13172 1882
    b 4 0 1053 0 3021 1399
    p 2 4 927 122 13533 1907
    b 4 0 1053 0 3308 1493
    p 2 19 906 128 13806 1981
    b 4 0 1053 0 2346 1338
    p 2 17 905 131 13327 1962
    b 4 0 1053 0 2813 1490
    p 2 11 902 140 13028 1948
    b 4 0 1053 0 3276 1476
    p 2 32 890 131 13721 1991
    b 4 0 1053 0 3353 1432
    p 2 51 866 136 13878 2095
    b 4 0 1053 0 2691 1283
    p 2 58 861 134 14712 2153
    b 4 0 1053 0 3533 1538
    p 2 66 846 141 17319 2085
    b 4 0 1053 0 3245 1391
    p 2 27 912 114 17042 1938
    b 4 0 1053 0 2587 1128
    p 2 8 907 138 14465 1729
    b 4 0 1053 0 3334 1345
    p 2 12 916 125 16221 1718
    b 4 0 1053 0 3569 1393
    p 2 15 932 106 16635 1835
    p 2 11 920 122 15938 1654
    i 2 1053 0 0 23339 3886
    b 4 0 1053 0 4532 2167
    p 2 90 851 112 18787 2440
    b 4 0 1053 0 3671 1781
    p 2 42 884 127 16258 2202
    b 4 0 1053 0 3856 1924
    p 2 25 910 118 18392 2230
    b 4 0 1053 0 3763 1983
    p 2 47 895 111 16923 2396
    b 4 0 1053 0 4315 2291
    p 2 46 889 118 16477 2422
    b 4 0 1053 0 4009 2078
    p 2 44 888 121 15916 2480
    b 4 0 1053 0 3798 1964
    p 2 31 894 128 15402 2276
    b 4 0 1053 0 4103 2110
    p 2 37 887 129 14342 2312
    b 4 0 1053 0 3154 1924
    p 2 33 890 130 12344 2233
    b 4 0 1053 0 3260 1864
    p 2 44 889 120 12598 2291
    b 4 0 1053 0 2793 1778
    p 2 14 910 129 10707 2053
    b 4 0 1053 0 2543 1734
    p 2 12 914 127 10891 2035
    b 4 0 1053 0 2513 1790
    p 2 29 889 135 13204 2277
    b 4 0 1053 0 2280 1665
    p 2 27 900 126 10470 2162
    b 4 0 1053 0 2299 1637
    p 2 35 857 161 10191 2168
    b 4 0 1053 0 2659 1853
    p 2 52 851 150 11550 2329
    b 4 0 1053 0 2936 2042
    p 2 48 891 114 12906 2515
    b 4 0 1053 0 3155 2156
    p 2 54 891 108 11819 2504
    b 4 0 1053 0 3094 2187
    p 2 55 880 118 10853 2474
    b 4 0 1053 0 3103 2299
    p 2 52 894 107 11235 2616
    b 4 0 1053 0 2930 2109
    p 2 46 890 117 11654 2504
    b 4 0 1053 0 4199 2368
    p 2 363 567 123 18017 3408
    b 4 0 1053 0 2758 1892
    p 2 37 885 131 13088 2426
    b 4 0 1053 0 2647 1911
    p 2 34 886 133 11659 2358
    b 4 0 1053 0 2836 2004
    p 2 48 862 143 12607 2438
    b 4 0 1053 0 3411 2147
    p 2 71 842 140 13887 2551
    b 4 0 1053 0 2808 1949
    p 2 38 878 137 12787 2382
    b 4 0 1053 0 3042 2157
    p 2 54 864 135 13553 2516
    b 4 0 1053 0 3543 2190
    p 2 51 861 141 13832 2537
    b 4 0 1053 0 3937 2325
    p 2 55 867 131 14214 2605
    b 4 0 1053 0 3534 2272
    p 2 64 855 134 15516 2639
    b 4 0 1053 0 4283 2636
    p 2 110 801 142 15914 2767
    b 4 0 1053 0 4249 2695
    p 2 77 833 143 14603 2733
    p 2 49 864 140 13198 2467
    b 4 0 1053 0 5952 2744
    p 2 141 767 145 19473 3019
    b 4 0 1053 0 5598 2645
    p 2 155 755 143 17093 2934
    b 4 0 1053 0 4950 2701
    p 2 158 748 147 15242 2907
    b 4 0 1053 0 4659 2729
    p 2 127 788 138 15919 2936
    b 4 0 1053 0 5645 2871
    River Tam: ''Can't look, can't look!'' My old avatar: dress, movies
  1. Converting xvid movies
    By SJRSMITH1 in forum DVD Ripping
    Last Post: 13th Jul 2011, 23:26
  2. Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
    By Peter25 in forum Newbie / General discussions
    Last Post: 9th Apr 2009, 18:10
  3. 870717 - converting TS to Xvid
    By ilostmyid2 in forum Video Conversion
    Last Post: 22nd Sep 2008, 09:58
  4. Converting .Xvid to DVD.... Please
    By Galosat in forum Authoring (DVD)
    Last Post: 18th Sep 2007, 15:10
  5. Converting from DVD to XVID
    By morphjk in forum DVD Ripping
    Last Post: 23rd Jul 2007, 16:33
