I love this player. It handles all the videos I put in there.
I have one complaint. To fast forward, you have to use the right arrow, and to rewind you have to use the left arrow. I figured this out after almost throwing the remote across the room because you 'could not' fast forward.....
It has the same problem when being controlled by my universal remote using standard philips codes. It looks like there is some weird key mapping issue. Does anyone know if there is a fix for this. Maybe a firmware update?
Thanks for any help.
That is the way they all work, yours isn't any different.
Google is your Friend
oh well, thanks for the answer
ar
Mine works the same way. I'm curious as to why you are perturbed about this; i.e., which keys would you map to FF/REW if you could? I'm talking about the Philips remote, which only has the arrows and Next/Previous track keys, as opposed to a universal remote which might have dedicated FF/REW keys.
Universal remotes are the way to go!
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate!
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
