    Jul 2005
    Fort Worth
    When I try to open an avi in sound forge to extract the audio as a wav file (some of my vid's won't extract in full processing mode with VirtualDub), I get the error that the file is an unsupported format. From what I read, I thought Sound Forge could open an avi. Am I missing something?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    there are over 50 types of avi files .... what kind is it ?
    many SF will not open ...
    Jul 2005
    Fort Worth
    i'm not sure if this is what your asking (i'm a noob), but they are movies which are either xvid or divx with mp3 or ac3 audio.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    sf will not open ac3 either ..
    sfhas problems opening divx or xvid , though if you have the right codecs installed and set up , often changing the 4CC to DiVX/DiVX will work ...
    i would just use virtualdub, specially if the audio is mp3 VBR , which sf also doesnt handle - or try goldwave
  5. It needs the plugin it is prompting for and it needs to be purchased. Can't remember the name of codec Video Concepts or something like that.
    Jul 2005
    Fort Worth
    thank you guys! i'll check out goldwave...
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    there is no plug in you need to purchase for opening avi files
