I have some episodes and their external greek subtitles in .srt format. I have in my pc Windows XP Home Greek and when I open the avi file the Greek fonts of the greek subtitles appear correctly. I use the DirectVobSub filter.
Now in my husbands pc (he has Windows ME English) using again the DirectVobSub filter the greek subs appear in un readable fonts. He also opened the .srt file of the subtitles and the greek fonts there are also unreadable. What can we do to fix this problem? What does he have to change so that he can see the correct greek fonts while playing the avi file?
Your husband's OS/Word-processing program needs Greek language support, which you happen to have but he doesn't. When you open .srt subtitle file, wordpad opens it. So unless language support is provided, it can't render the language.
Alternatively you can convert the .srt file in your computer to bitmap (.idx) subs and use that with the video file. Bitmaps are picture elements - not text - and so will be shown correctly.
Thanks.
I have a similar problem. I can see the Greek subtitles correctly in my PC, but when I try to see the same thing on my standalone DVD player that plays Divx movies, the subtitles are just unreadable (funny characters appear on the screen). Do I have to convert them into an other format so that my DVD player can read them? My player is LG LH-T360SE and I use srt subtitle format.
Thanks.
Hi orentios
Your problem is covered by my reply above.
Regards.
Some standalone DVD players that support Divx only work with limited character sets. For example, I have the Philips DVP-642 and it only can display Latin and Cyrillic character sets. That's it. If your LG player has similar restrictions, you need to follow ukb007's advice and convert the subtitles to idx format and hopefully your player will display those for Divx.
No need to do that. I found in my LG DVD player that if I keep pressed the subtitles button for about three seconds I can then change the character set. I found the greek one... so no problem any more.
Greek subtitles problem
By MultiNikos in forum SubtitleReplies: 30Last Post: 30th Apr 2012, 15:32 -
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 07:45 -
greek subtitles do not show at all!!
By eleeeni in forum ffmpegX general discussionReplies: 6Last Post: 27th Jul 2011, 14:09 -
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 05:52 -
GREEK sUBTITLES HELP.
By AndreasTorous in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 11:07
