I have an avi which is 23.97 fps,i have subtitles which are in srt format,but at 25fps.I cant find subtitles for 23.97.My question is can i convert the avi to 25fps and then use the srt file at 25 fps ,will it be in sync?
Thanks in advance
Thread: avi is 23.97fps,srt is 25fps
Could also try adjusting the srt to 23.976fps. As to whether it will be in sync, really depends whether the PAL version had a different length intro, etc.
If you do change the framerate of the avi, you will also need to change the duration of the audio to match.
Thanks for your reply.I guess i will have to wait for the right srt file(i put in a few requests on subtitle sites).I had a try with a few subtitle tools,but could not grasp it.Originally Posted by celtic_druid
this is the toll i use if the srt i have doesnt match my avi
Subsync:
http://users.pandora.be/vlad/subsync/
guide here:
http://www.weethet.nl/english/video_syncsubtitles.php
good luckI love it when a plan comes together!
Ricardo Santos
Thank you very much,that was a very user friendly guide.Best of all it worked.Much appreciated.
glad it worked.
Ricardo Santos
A bit late as reply, but I found this utility that allows to convert online into a different format and change the fps on the fly. If the subtitles are shifted (too soon or too late) you can adjust the time as well.
Still a lot easier than to modify them all by hand yourself
http://www.alterlinks.com/subtitle_conversion/index.php
Only by 3 1/2 years.Originally Posted by Drubi
Why not start a new thread or just submit this as a new tool in the tools section.
No need to dig up an old thread. Especially one that was already solved.
why 25fps avi or 23.97fps avi
By theewizard in forum DVD RippingReplies: 8Last Post: 12th Jun 2007, 09:03 -
Pal (25fps) to 23.97fps or 29.97fps???
By tarrickb in forum Video ConversionReplies: 2Last Post: 25th Mar 2006, 23:27 -
Convert 23.97fps (AVI) to 25fps (PAL DVD)?
By basquille in forum Video ConversionReplies: 0Last Post: 13th Mar 2004, 09:55 -
Problem: NTSC 29.97fps avi to PAL 25fps VCD
By rhegedus in forum Video ConversionReplies: 1Last Post: 17th Dec 2002, 05:11 -
How to convert an AVI-file from 23.97fps to 25fps?
By Blizzy in forum Video ConversionReplies: 2Last Post: 21st Jan 2002, 16:36
Newest guidesLatest tool updatesNew media commentsReplay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
