Has anyone ever found out why Vcdeasy starts with an error saying Windows Media player not installed? I have installed several different versions with no luck. I am using Windows xp sp2.
Thanks.
Thread: Vcdeasy and media player?
Nevermind....figured it out.
msdxm.ocx.
It wasnt present so i downloaded it and registered it with regsvc32 and now vcdeasy opens.
Speaking of msdxm.ocx, I've come to the conclusion that this file gets registered (as in regsvr32) every single time VCDEasy starts up. This is not a good thing!
A few days ago, after installing and running the VCDEasy 3.0.2 trial version, I found that my Windows Media Player browser plug-in was screwed up -- all embedded media was being played by the outdated WMP 6.4 instead of the current WMP 10!
After some hours of head-scratching and searching, I learned that msdxm.ocx was likely the cause of this problem, and the solution was to re-register wmpdxm.dll. Although that solution works great and gets rid of WMP 6.4, starting VCDEasy again makes the problem come right back.
As it would be quite a hassle to re-register wmpdxm.dll every time I use VCDEasy, I really hope the developer can fix this bug.
References
MCSE.MS - IE6 uses wrong (old) version of WMP
Microsoft Knowledge Base: Windows Media Player 6.4 is embedded in Web pages even when Windows Media Player 9 or 10 is installedPresumably you installed an old software package over the top that misregistered v6 player components. I've got some code around that tries to avoid that/fix that up where possible, but presumably you found an old install package that bypassed that prevention code.
This behavior occurs because the Windows Media Player 6.4 ActiveX control, Msdxm.ocx, was reregistered.
To resolve this behavior, reregister the Wmpdxm.dll file.
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 00:18 -
Windows Media Player OR Media Player Classic REMOTES?
By Xenogear900 in forum ComputerReplies: 2Last Post: 7th Dec 2006, 17:04 -
VCDEasy and Windows Media Player
By jtbterri in forum Authoring (VCD/SVCD)Replies: 3Last Post: 28th Dec 2002, 11:03 -
VCDEasy Won't Play on DVD Player?
By Kiwi Kid in forum VCDEasy GeneralReplies: 4Last Post: 10th Oct 2002, 02:53
Statistics
Newest guides
Latest tool updates
New media comments
