VideoHelp.com Forum
  1. Member BrainStorm69's Avatar
    I just received a used Datavideo TBC-3000 that I bought on ebay. The manual I downloaded from Datavideo's US site says the power supply for the TBC-3000 is 9 volts and 10 watts (1111 milliamps). The power supply the seller shipped is 12 volts and 400 milliamps (4.8 watts). I have not tried testing out the unit since this is obviously the wrong power supply. I have just sent an email to the seller about this.
    Can someone who is more knowledgeable than I about this tell me whether using this power supply with this unit will damage the unit? As I mentioned, I am concerned about testing it with this power supply. I'm also concerned about whether the unit could be damaged if the seller used this power supply with the unit previously.
    TIA.
  2. Preservationist davideck's Avatar
    Funny - the same thing happened to me. I bought my TBC-3000 from EBay and it arrived with an underrated power supply. 12V at 400mA will probably not work. There are internal regulators inside the TBC-3000. The Power Supply will probably be unable to maintain 12VDC and will drop below the voltage required to allow the regulators to operate properly. That's what happened in my case. It did not harm the unit and I don't think you will do any damage either. But you will need a better supply.
    I contacted my seller and asked him to refund the amount required to buy an appropriate power brick from Radio Shack. He was happy to do so.
    I am currently using a 9VDC 1.2 Amp brick that really bakes after the TBC-3000 has been on for an hour or so, so I wouldn't recommend anything less.
  3. Member BrainStorm69's Avatar
    David, thanks for the info. Assuming that the seller doesn't have the proper power supply to send to me, I think I'm going to do exactly what you did - ask him to refund the amount it will cost me to buy a proper ac adaptor.
    PS, since you answered here, please ignore the PM I sent you.
  1. Datavideo TBC-1000 Power Supply (PSU)
    By Gibson's Squares in forum Restoration
    Last Post: 1st May 2012, 19:22
  2. External power supply question (media center related)
    By dbanimal in forum Media Center PC / MediaCenters
    Last Post: 16th Sep 2011, 00:49
  3. Question about new Power supply ?
    By VEBouto in forum Computer
    Last Post: 8th Oct 2010, 14:36
  4. Power Supply Question
    By jjis in forum Computer
    Last Post: 6th Nov 2009, 07:35
  5. Samsung DVDHD1080P7 Power Supply Question
    By lonaman in forum DVD & Blu-ray Players
    Last Post: 31st Oct 2007, 02:52
