Page 7 of 8
FirstFirst ... 5 6 7 8 LastLast
Results 181 to 210 of 235
  1. VDubMod isn't a (very good) player. Don't worry about the lack of sound. Now, if you don't get any audio when using a real software DVD player, then you can begin worrying.
    Yeah manono...thanks a lot. It worked!! But i recently encountered another problem. When i opened a vcd file, i can't seem to choose which audio stream i want to use. When i play that file using my dvd player after i burned it, the audio comes from the left and right speaker, which means 2 languages being played at the same time. And i don't think i can disable one of the speakers (since i'm using a dvd player instead of a vcd player). Is there anything i can do about it? Right now, i'm using my PC to play that file cuz i'm able to switch off one of it's speakers but i would prefer using the dvd player. Pleasseee help!
  3. I don't work with VCDs, sorry. However, if you have audio divided like that, the procedure might be to extract the audio and convert to WAV audio, if it's not already. Open it in a WAV Editor. Isolate each channel in turn and save them separately as 48000Hz WAV mono audio tracks. You can then create dual channel mono audio if you like, before then converting to AC3 (or maybe MP2) audio. Use the 2 new audio tracks in the DVD.
    Is there a way to make vitrualdub (vitrualdubmod) when finished a avi with subtitles, to start another avi file with other subtitles etc..????
  5. That's what the Job Control is for. Queue them all up and then start the Job Control going to encode them one after the other.
  6. Banned
    Yes you can --- if your DVD player is a decent one, I mean.
    Anyway, sadly most ppl do not want to take the time to RTFM.
    Queue?? What do u mean??
    Ok let's say i have avi 1 with thesubtitles 1
    avi 2 with subs 2
    I put avi 1 and filter for subtitle 1, i set the framerate, the conversion type etc. I am one step before i click on "save as"
    then what i do to put it on job control and to start with avi 2??
    Ok i am stupid!!!
    Found it. You click save as and then you tick on "Don't run this job now..."
    Ok new problem. I put the avi with the textsub filter and set it Arial size 20. Save as=job control
    I put the second video with the same settings for textsub filter (Arial size 20) save as=job control
    BUT when i start the job control i realized that the settings of textsub goes to 18!!!
    If i start the process one by one file then there is no problem!!!
    Any ideas??
    In Virtualdubmod open your video. (If a message popups that VBR audio stream detected just select NO)
    Add the TextSub filter under Video->Filters.
    Open the srt, sub(text), smi, ssa subtitle.
    (If you have an idx/sub/ifo subtitle add the VobSub filter intead.)
    Textsub is not listed as a filter.
    It goes from Temporal Smoother to Threshold
  11. Above what you quoted from the guide, did you see and do this:
    Download Vobsub 2.23.
    When you install VobSub be sure to select VobSub for Virtualdub and TextSub for Virtualdub and AviSynth under Plugins:
    Ok, I was really trying to figure this out without help, but I'm stuck.
    I installed vobsub and the plugins for virtualdubmod. I opened my video file, selected the textsub option and tried to open my srt file. But thats where I run into problems. When I select the srt it dumps me back to the textsub settings screen. The subtitle file dosent open and I cant go on.
    The subtitles are styled subs if that matters.
    Thank for sharing.You can add permanent more easier.
    Just us VobSub
    Start
    The window will display here
    Just drag and drop the movie and sub to the windows as it instruct you.
    Please help me to add switchable sub to avi to create divx file.Please post it here.
    http://forum.videohelp.com/topic339829.html
  14. Member tenma's Avatar
    Thanks a lot Baldrick! I though I was at a dead end when the Vobsub filter just will not work for some reason. It is a good thing that I remembered I had VSfilter before. After renaming that dll file, srt files are now working for me.
  15. Member tenma's Avatar
    Try to install a VSfilter. I installed it from a codec pack called K-lite, found it on codecs.com. On the filters folder of the K lite package, you will see a vsfilter.dll file. You need to copy that file and paste it on the plug in folder of VirtualDub. Lastly, you need to rename that file to a .vdf. When you go back to the filters on the VirtualDub, you can add either textsub or vobsub and it should work.
    Bless you, Baldrick! You are the best!
    I used to add subtitles to my videos and it worked fine, but then I had to replace my HD and for some reason I could not add subtitles and I had no idea why, and now thanks to you I know what was my mistake.
    Thank you million times~
  17. how do i do that?
  18. I'm a MEGA Super Moderator Baldrick's Avatar
    Use virtualdubmod instead and click no if it asks if you want to rewrite the header.
  19. Member kevin182h's Avatar
    my virtualdubmod has the same problem...
    well, i have the one that AutoGK installed by itself
    I get the error code-2 all the time when I'm gonna save it and I have checked what it says in here but Xvid doesn't have any format destrictions. Can someone help me?
    Just us VobSub
    Start
    i have also tried this, but the subtitle files i am using are .sub and there is also .idx subtitle files. i don't think that SubMux supports these?
  22. Member
    I have a problem when i try to Save As Avi.
    _who same me, plzz help me
  23. I'm a MEGA Super Moderator Baldrick's Avatar
    seaboy: What video compression are you using? Under Video->Compression.
  24. Member
    XviD MPG-4 Codec. And with VirtualDubMod_1_5, it have same error . I use K-lite Mega Code Pack
  25. I'm a MEGA Super Moderator Baldrick's Avatar
    You might get that error if you are doing 2-pass encoding and haven't made the first pass. Check the xvid settings under file->compression and click configure, set it to 1-pass if it's 2-pass.
    If that wont help try download latest koepis xvid codec and (re)install it.
  26. Member
    Thanks so much, it's working now, but i don't understand why i can't use 2-pass , i think it will better than singel pass.
  27. Baldrick is saying you get that message if you haven't already run the first pass. You have to set it for Twopass-1st pass, followed by Twopass-2nd pass, saving each in turn. They can be made to run back to back by saving to the Job Control followed by going there to start the encode.
    It's not, although you lose control over the file size when running a single pass set for a target quantizer (not target bitrate).
  28. Member
    I had done 3 video, but with fourth Video is happen this error:
    And i try with other Video, it still happen this error . How can i fix it? Plzz help me.
  29. Member
    edit: please delete this post
  30. Member
    I have a new problem when I use VirtualDubMod to open a video file (*.avi). A report appear as below:
    _VirtualDub has detected an improper VBR audio encoding in the source AVI file(audiostream1). The current preference is to rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 12751 ms of skew from the video stream. If this is unacceptable, decompress the *emtrie* audio stream to an uncompressed WAVfile and recompress with a constant birate eoncoder. (bitrate: 125.4+- 17.0 kbps).And choose yes or no.
    _Although I choose yes or no. When i preview, Video sound is not good. Sound don't coincisive with video. It's too lag and cracked. How can i fix this mistake? Plzz help me.
  1. Replies: 8
    Last Post: 19th Jul 2008, 03:32
  2. Replies: 11
    Last Post: 29th Nov 2005, 19:08
  3. Replies: 6
    Last Post: 4th Jun 2003, 03:37
  4. Add permanent a subtitle to a SVCD file.
    By Tijger007 in forum Video Conversion
    Last Post: 30th Dec 2002, 04:17
  5. Add permanent subtitle on a svcd??
    By Skippy in forum Authoring (VCD/SVCD)
    Last Post: 25th Dec 2002, 17:22
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
