VideoHelp.com Forum
Results 1 to 20 of 20
    I am sort of new to this but have a tad of experience. I am runnin a G5 Dual 1.8 GHZ processor and have about 30gb free space and over 1gb of RAM. I currently had some DVD Rips of some movies and used ffmpegx to convert them over and burn them to DVD using toast. I used the presets that ffmpegx offers and I get a folder with a video_ts and audio_ts, but when I burned the folder using toast under the UDF I put it in a DVD player and the video played with no sound.
    So I checked the original DVD Rip Divx AVI and it had sound and picture and was perfect.
    So i went to the folder I burned and I checked the audio_ts folder and it was empty. I noticed that ffmpegx after converting gives me addl files along with the folder with the audio and video_ts. It gives me .mpv and .ac3 files. I dont know if I need those or its just part of the converting process. I dont know if there is an easier way using ffmpegx or a better way on MAC.
    If anyone can help, please let me know!
  2. The AUDIO_TS folder is always empty. Try to load the VIDEO_TS folder in VLC and check if there is sound. If yes try to change the audio track from 0 to 1 with your remote control.
    K, I opened up the TS Folder in VLC and the video played but no sound still...also the video seemed to be stretched while the Divx original seems to be perfectly proportionate. Is there something wrong that I am doing in the encoding stage, or maybe something wrong with the presets or picking the wrong preset in ffmpegx?
  4. If you open that VIDEO_TS folder in ffmpegX, does the summary tab show the audio format?
    Yes, I opened the TS_Video folder in ffmpegx, and the audio under the summary says ac3, 48000Hz, 448 kbps. I cant figure it out..and like i said the original divx AVI has audio when i open it in VLC. I am wracking my brain over this and I cannot seem to figure this out!
  6. Try again VLC, and check the "Audio > Audio track" menu. Does it contain any track?
    Oh wow! Yea, I opened the file in VLC and then opened up the audio track and saw that there was another track...there was a 0 digital and then 1 stereo. I selected 1 stereo and then......VLC crashed. I restarted, did it again and VLC crashed, restarted one more time and VLC crashed again. So that is where I am now...any suggestions?
  8. Try the same in your DVD Player, you should have a button somewhere to select the audio track. Check if you have audio in track 1 instead of track 0.
    When I put it in the DVD player, I checked the audio and it only gives me 1 option for audio. It says audio 1/1, and it produced no sound.
  10. Sorry that it will take time to do so, but,
    1/ make sure you can play your AVI in Quicktime Player with audio
    2/ if 1/ is successful then encode your AVI again, this time use "DVD mpeg2enc" as target format and also select MP2, 48000 Hz, stereo in the audio tab.
    i put the original XviD.AVI in QT and no picture or sound produce. I brought it into VLC just to triple check myself and it does produce sound and picture.
  12. Then try to install the divx codec for mac from www.divx.com and try again from step 1/.
    k i installed the divx codec and i was able to see audio and video on Quicktime. So I will no go and try to encode it in ffmpegx as mpeg2enc and change the audio to MP2, and see if that works.
    When I select the preset for the mpeg2enc the video size is different from the AVI, can I set it manually so that it will stay the same proportions or will that screw everything up?
  14. No, the video size is standardized for DVD and you must not change it.
    k, so I didnt change the video and now I have a .M2V,.MP2, and a .WAV file. What do I do now to put this on a disc or to check to see if it works on a DVD?
  16. The encoding is not finished, wait for the message "Finished" in the progress window to appear.
    the progress window indicated that the file was finished, that is all the files that I have...should I have had some other files..like a DVD folder with Video and Audio_TS?? If thats the case I will have to try again as it did not give me any additional files.
  18. The following items are created in the following order, m2v, wav, mp2, mpg, VIDEO_TS. Make sure there are no spaces and special characters in your paths and filenames and check the process output (blue "i" icon) for any error messages.
    well I sent the AVI file once through and had only a .M2V,.MP2, and a .WAV file. I deleted it all, quit ffmpegx and did it again. The result was the same and the progress window indicated that it was finished. At this point I think it has to be the AVI file. So I decided to try another AVI file that I had to see if maybe it would work. I hope this file works, going nuts!
  20. I have been trying the same thing with an XVID I have. I have just used the the presets both for ffmpeg and mpeg2enc in that order. The only thing I changed was decoding with mplayer instead of quicktime since the .avi played smoother in mplayer. After everything was done I played a .vob file in VLC and everything seemed fine so I went ahead and burned my 2 folders. In my standalone player (Pioneer DV-C503) the video looks great but the audio cuts in and out. In my PS2 (slimline) it plays, but the video is jerky, almost as though frames are missing.
    I tried your suggestion of trying to change the audio channel on the first burn it it won't switch from the 5.1 channel. I'm not sure where to proceed from here.
  1. My DivX DVD Player can't play my avi DivX/xvid video
    By Baldrick in forum DVD & Blu-ray Players
    Last Post: 31st Jan 2012, 07:07
  2. A DVDRip.Xvid.AC3 won't play in Bluray player
    By David Banner in forum Newbie / General discussions
    Last Post: 10th Nov 2011, 13:48
  3. Replies: 8
    Last Post: 9th Sep 2009, 07:26
  4. Does a Divx DVD player play xvid?
    By Gerrich in forum Video Conversion
    Last Post: 22nd Feb 2009, 01:36
  5. Is this DVD Player can play Divx or XviD?
    By php111 in forum DVD & Blu-ray Players
    Last Post: 6th Oct 2007, 07:29
