Hi Guys
I have Ulead Movie factory 3 and i have authored MPEG 2 files and i burned it on DVD but when i play the DVD as there are 10 clips and after each one plays it wont go to the next clip and it will skip to the menu.I have double checked and MF3 is selected to "Play the next clip" after that clip finishes playing.And in PAL.What could be the problem and is there anything i could do?
There is a Project settings button done the bottom of MovieFactory.
It'll bring up a window like the following pic.
At the bottom is an option to play the next clip or go back to the menu.
Hi Scott
I did exactly that to and selected to play the next clip but im still experiencing the same problems.I tried to use NeroVision 3 and when it encodes the 3rd of my 10 clips it crowls to a halt and wont transcode anymore.
Please help me as my clips i taking more space on my PC.
Thank You
Dieter Rencken
Sorry, if it's not playing the game even though you make the correct setting I can't really help.
Definitely give Nero the flick though.
Download the trial version of DVDlab and give that a go. I might look difficult to use but once you get used to it it's a breeze. Well worth the money!!!!!!!!!!!
http://www.mediachance.com/download.htm
Perhaps others have better suggestions.
Good luck
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
DVD skips the menu and automatically plays the main movie!
By kreky in forum Authoring (DVD)Replies: 7Last Post: 17th May 2008, 07:14 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 13:12 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20
Statistics
Newest guides
Latest tool updates
New media comments
