I have a Sony analog camcorder. It has the red white and yellow connectors and I want to be able to hook this up to my laptop. My laptop has USB ports and everything. I was wondering what kind of adaptor do I need to get so that I can put all the footage from the camcorder to my hard drive so I can work with them and eventually create a DVD out of them.
Thread: What adaptor do I need?
Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall
How about a PCMCIA capture card? Or as a alternative, there are a few external capture boxes that have a USB 2.0 output.
Ohh...so I need a capture card not just a little adaptor thing to make it go from red yellow and white to USB. I dont know anything about capture cards. Does anyone have any suggestions?
I dont know how this works but just found it at walmart website.
Xpert DVD Maker USB 2.0 Video Capture Device
http://www.walmart.com/catalog/produ...32959%3A164215
Your desktop computer with 3 Ghz P4 is much more suited for creating DVDs
It has to convert the analog signal to digital. Check under capture cards to the left, it doesn't have to be a card. They make them for firewire or USB. Make sure you have USB2 on your laptop and the device is USB2 if you want USB.Originally Posted by SEALs1230
AC to USB Power Adaptor
By Frank-0-Video in forum ComputerReplies: 2Last Post: 4th May 2011, 09:49 -
power adaptor
By n0p3 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2009, 21:21 -
what adaptor for protable hardrive should i use.
By krnjason in forum ComputerReplies: 7Last Post: 28th Nov 2008, 07:45 -
ASUS TV Tuner problem with Video in & audio adaptor
By Zpazt in forum CapturingReplies: 0Last Post: 16th Jul 2008, 14:30 -
AC adaptor for PANASONIC PV-GS39
By crocker5731 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 2nd Sep 2007, 14:59
