Hi, guys,
Iīve got me a new machine:
motherboard A8N-SLI
AMD Athlon 64 3500+
nvidia Geforce 6600 GT
1 GB Ram DDR2
Now I need a good tv capture card.
Something not very pricey but really good that is easy to install, just plug the VCR cable on it and voilá.
(Assume that Iīm remarkably stupid when it comes to computers)
What would you suggest?
Thread: Recommend me a capture card
"They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
When you play it forward, it installs windows."
http://www.ati.com/products/tvwonderusb20/index.html
Works great, should be less than $75 at local stores, maybe less than $50 online. Nice and simple.
Your rig is similar to mine btw (ignore my profile), so consider that this product has been tested and works.
-Evan-
Hey, thanks a lot, QuaiBoy, thatīs exactly what I was looking for.
Edit: Dóh!
I just realised itīs for NTSC.
I need Pal.....
QUESTION: how did you realise its for ntsc? Will this card recognize only ntsc signal? how can you tell/find out? it doesnt say anything like that in the description/overview/features on the ati website. how am i supposed to find out which card supports both ntsc and pal sources as inputs if offical ati descriptions say nothing?
Recommend Capture card/stick pls
By jubbely2 in forum CapturingReplies: 5Last Post: 27th Oct 2010, 12:14 -
Can any one recommend a tv capture card?
By Stevet1972 in forum Video StreamingReplies: 2Last Post: 19th Nov 2009, 06:08 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum CapturingReplies: 12Last Post: 13th May 2008, 17:52 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum CapturingReplies: 7Last Post: 5th Feb 2008, 07:25 -
Recommend AGP 4x capture card for P4 2.4GHz computer please??
By w@ntonsoup in forum CapturingReplies: 16Last Post: 9th Oct 2007, 11:05
Statistics
Newest guides
Latest tool updates
New media comments
