VideoHelp.com Forum
Thread: deinterlace
  1. im totally new to computers and not able to understand much of the technical language im coming across. i watch a lot of downloaded avis or mpegs of varying quality and im trying to work out how to use deinterlace settings on vlc but have no idea when and which settings to use. would be grateful for a simple explanation of the different deintelace settins on vlc if possible.
    Are you sure you need to deinterlace? It's unusual to need to do that to downloaded material. DV and MPEG2 captured video from television might need it, but otherwise...
    Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
  3. Explorer Case's Avatar
    Disable = Off
    Blend = Blend two fields to one progressive frame
    Bob = Convert fields to frames and double the framerate
    Discard = "Even Fields Only" or "Odd Fields Only"
    Linear = ?
    Mean = ?
    It's not just only a difference in quality, but in CPU utilization, 'cause dropping frames during playback would be worse than any sub-optimal filter.
  4. maybe that explains why it seems to make no difference
    If, when you're viewing something in VLC, you're bothered by combing (jagged edges on moving objects that look like the teeth on a comb) then you need to turn deinterlacing on. Blend usually works best. If you don't see combing, then you don't need it. It depends on the source material.
  6. And if you need to edit such footage, then Jes's Deinterlacer is a great solution.
    Available on versiontracker.com (and free).
  7. No Longer Mod tgpo's Avatar
    I've never had to use the deinterlace option in VLC. And never, never use it on my videos. I make my videos for use on television sets, thus keeping my stuff interlaced is what I want.
    Not that this comments helps you in any way, but I thought I'd just throw this out there.
  1. Deinterlace
    By leftspeaker2000 in forum DVD Ripping
    Last Post: 5th Dec 2011, 05:17
  2. Deinterlace?
    By ZedsDead in forum Video Conversion
    Last Post: 14th Mar 2010, 23:21
  3. To deinterlace or not deinterlace...
    By Nilfennasion in forum Mac
    Last Post: 4th Dec 2008, 00:46
  4. Do I need to deinterlace? Or never deinterlace?
    By rbatty11 in forum Video Conversion
    Last Post: 17th Jan 2008, 13:15
  5. What Deinterlace does in Avi2Dvd?
    By geek2330 in forum Newbie / General discussions
    Last Post: 24th Jun 2007, 20:51
