VideoHelp.com Forum
    I finally sucked it up and bought a pack of Ritek Dual Layer media in hopes of burning a few discs that I couldn't fit onto single layer media. After wrangling with Nero (had to upgrade the version to 6.6.0.14) and my NEC 3500 burner (had to upgrade the firmware to 2.19), I succeeded in burning a disc, which seems to play fine on my computer. But when I put it in my Sampo DVE-661 standalone player (which I flashed with a region-free firmware long ago) it says "Loading" for 2-3 minutes, and then says "no disc".
    This is the first time I've had any problem with any media I've thrown at this player. Does anyone know if there's something I can do to make my trusty workhorse handle DL discs?
    thanks
    -L
  2. you might need a different player. DL is a crap shoot. its rate of compatibility is extremely low these days.
  3. Member thevoelk's Avatar
    If you're burning a backed up DVD, make an ISO with DVD Decrypter and burn it with Decrypter. Make sure you burn with the booktype set as DVD-ROM, not DVD +R DL.
  1. copy protection on home-burned DVD?
    By hillneerg in forum Newbie / General discussions
    Last Post: 23rd May 2011, 15:20
  2. Burned home-video DVD looks not deinterlaced on tv
    By granturissimus in forum Newbie / General discussions
    Last Post: 8th Jan 2011, 09:59
  3. Cannot play burned dvd on home dvd player
    By ellemacamelle in forum ffmpegX general discussion
    Last Post: 11th Aug 2010, 18:18
  4. dvd's I burned do not always play on television
    By geminidreamer in forum Newbie / General discussions
    Last Post: 14th Nov 2009, 18:29
  5. Marantz PMD 661 questions
    By danielmak in forum Audio
    Last Post: 6th Oct 2009, 14:23
