so... i've got a 2wire DSL modem/wireless router. problem is it's only a .11b wireless. so i got a dlink 524 .11g wireless router to add to the mix. so the orig config was, DSL/2 wire and to the desktop wired and the laptop wireless. everything worked fine until i decided i knew what i was doing and updated the firmware without saving the previous setup for the dlink.
now the dlink doesn't talk to the 2wire, i don't anything other than LAN when connected in the original setup (2wire>dlink> desktop (wired) and laptop (wireless)) . i can xfer files, use vnc between the laptop and the desktop while in the orignal phys config, but that's it. nothing communicates outside the dlink. i tried assigning the IP, Primary DNS the same as the 2wire says the internet connection is. nothing, i tried using the dynamic IP setting, didn't work. i tried throwing it across the room, that didn't work. i just want to be able to get my signal AND internet from my dlink. is that so hard?
what should i check to make sure the two can communicate properly?
Results 1 to 1 of 1
Lan Drivers
By Soixante in forum ComputerReplies: 7Last Post: 11th May 2011, 19:16 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 6th Aug 2007, 23:26 -
Wireless LAN with B and G devices
By bobogs in forum ComputerReplies: 4Last Post: 18th Jul 2007, 03:24 -
5.1 over LAN
By prizi in forum ComputerReplies: 6Last Post: 10th Jun 2007, 14:06
