My family just bought s brand new entertainment system for christmas, and we went ahead and installed it all this morning. Its suround sound all of that. Now, all I am wondering is if it will play vcds. Like ripped dvds. It says in the box that is supports cd-r and cd-rw so I know it plays those. I just want to know if it plays dvds so I can burn them for my family.
The model number on the box was
Pioneer HTP-510DV
Thanx for all of your help
Hi
Don't see it in this list;
http://www.techtronics.com/uk/shop/5...vd-system.html
Most cdr/cdrw do play VCD's.. WHY NOT TRY IT AND SEE ???
OK, I quess I will but i saw somewhere in the manual it says it plays mpeg 1 or something like that
.... If it's got an MPEG1 decoder built-in to it AND it plays CDR/CDRW you should have no problem in playing a standard VCD.
NJoi!
Sue xxx.
i have the same model but it goes by the name XV-HDT1 here in the Philippines. It plays VCD's and SVCD's. My only problem with it is that the Time Search function doesn't work with my SVCD's. Only with the VCD's. Do you know of any solution for this?
Kiko
kikov@bigfot.com
Pioneer 420k DVD player for canadians
By victoriabears in forum DVD & Blu-ray PlayersReplies: 47Last Post: 30th Aug 2011, 09:26 -
Pioneer 533 DVD-R Burning Problem/Question
By tcfrerich in forum DVD & Blu-ray RecordersReplies: 27Last Post: 23rd Oct 2009, 12:03 -
Running Lines on Screen from Pioneer DV-355 DVD Player
By trini_davidg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Jan 2008, 11:36 -
Philips vs Pioneer upscale DVD player, which one?
By hanugro in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Dec 2007, 04:08 -
Qustion Dvd Player - Pioneer Dv393
By zaptos in forum DVD RippingReplies: 2Last Post: 28th Oct 2007, 08:26
