In order to change the bitrate of a mp3, both 4Musics and mp3to128 programs work, but I was wondering if there was another way or another FREEWARE (not shareware) that I can use to change the bitrate of the mp3
Results 1 to 10 of 10
You do realize that with any of those solutions, there is some loss of quality, right?
Many of us would rather leave the bitrate as is rather than re-encode from an mp3 source. But, to each his own...
Scott -
dbPowerAmp is great for a quick encoding to another quality. shell extension makes it a breeze
Is there any other way to change the mp3 bitrate and frequency WITHOUT the loss of quality?
no
you could try changing it up
i dont think you would loose any quality
you wouldnt gain any
just get a biiger file -
you would loose quality even going up in bit rate - as you have to decompress a very lossy format and recompress it again ..
Can you change the video bitrate with Multiavchd?
By jbitakis in forum Authoring (Blu-ray)Replies: 0Last Post: 28th Nov 2011, 00:57 -
Want to change a bunch of mp3 files to smaller bitrate
By happydog500 in forum AudioReplies: 6Last Post: 11th Aug 2009, 12:08 -
change audio bitrate in ConvertXtoDVD
By ecc in forum Video ConversionReplies: 9Last Post: 16th Nov 2008, 21:15 -
change video bitrate
By Ogilvy in forum EditingReplies: 2Last Post: 3rd Jul 2008, 13:07 -
How can i change an mp3 to a wav?
By pondleaping in forum AudioReplies: 7Last Post: 28th Jul 2007, 02:09
