Well, I have the 550pro and have been struggling for the past month to get the card to work with any software. I am now considering the Hauppauge pvr 150 mce card. Would this card be compatible with capture programs such as Pinnacle and Ulead? Does anyone here own both cards? What is the picture quality difference between the two cards? Thanks!
Thread: theater 550pro vs pvr 150mce?
Why can't you just import the clip with Pinnacle and Ulead?, Is it becuase the MPEG files generated by the Theater 550 Pro are not very compatible with some tools like let say Ulead DVD MovieFactory when I try set up auto 1 min chapters point it carp out after 6 min's in to it and using Womble MPEG-VCR MPEG "GOP fixer" I fine it show lot's of error in GOP time code which not good at all, But writing out a new files with Womble MPEG-VCR fix the problem.
As for Hauppauge PVR 150/250/350 and USB2
Pinnacle NO but you able to import the clip
Ulead YES in fact it come with DVD MovieFactory or you can download plug-in driver for full ver apps.
Strange problem with PVR 150MCE
By nigma in forum Media Center PC / MediaCentersReplies: 2Last Post: 5th Nov 2009, 20:36 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 08:26 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum CapturingReplies: 1Last Post: 11th Mar 2008, 09:04 -
Hauppauge 150MCE or 250PVR and what are you using for capture??
By GMaq in forum LinuxReplies: 11Last Post: 2nd Oct 2007, 10:35 -
Any Video Capture Software for ATI Theater 550Pro?
By quantass in forum CapturingReplies: 1Last Post: 8th Sep 2007, 18:26
Statistics
Newest guides
Latest tool updates
New media comments
