VideoHelp.com Forum
    I tried using Pocket DVD Suite to convert DVD to pocket format. Never Ever had as much problem with any software as I had with this one. Had work with Software and done conversions in the past without out much problems; this little software Hangs, give pdvd.exe errors. and other errors also.
    i tried all the suggestion written in their Tiny support website and nothing works.
    Is there any other tools and methods to do this
    thanks
    What exactly is pocket PC format supposed to be?
    Perhaps you just mean something that can be played back via say betaplayer?
    Convert to xvid with fairuse wizard, autogk, pocketdivx encoder. Just use a low resolution.
  4. The new Divx Converter, http://www.videohelp.com/tools?tool=DivX_Converter
    should be able to output in a format that you can play with Betaplayer on your Pocket PC.
    I meant basically a movie than can be play on a pocket pc. converting a dvd movie to size that could fit in a SD card a be able to watch it using a pocket pc
  1. Help please, easy format pocket camcorder?
    By Lilygrace in forum Newbie / General discussions
    Last Post: 23rd Aug 2010, 12:04
  2. Getting DVD rips on to aaxa p2 pocket projector
    By Duck in forum Newbie / General discussions
    Last Post: 19th Mar 2010, 12:32
  3. safe few bucks from my pocket
    By mrdin2005 in forum Video Streaming
    Last Post: 20th Jul 2009, 04:26
  4. Movie player for Pocket PC??
    By Cazz in forum Software Playing
    Last Post: 2nd Jul 2009, 15:39
  5. Replies: 0
    Last Post: 21st Apr 2008, 02:25
