VideoHelp.com Forum
  1. I'm wondering if anyone can help me out with something.
    I'm using DVD-lab Pro and am trying to figure out if there's a way to have it so when one video clip is done playing and returns to the menu, the following button is highlighted. For example, I select the first button, which is the first clip, then it returns to the menu after it's done playing, and button 2 is highlighted, when video 2 is done, it goes to the menu with button 3 selected, etc.
    I know that many professional DVDs have this setup and was wondering if it's possible to do it in DLP.
  2. You need switched menus.
    Tutorial in my sig.
    Cheers, Jim
    My DVDLab Guides
  3. Always Watching guns1inger's Avatar
    In DVD Lab Pro, go to the connection screen and select the first video clip. In the Links window (small window, by default below the connections screen), select your menu from the drop down. This should load a second drop down next to it. From here you can choose the button to return to. (Hope this makes sense)
    If you can't see the Link bar, go to the connections menu and select Link Bar.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Thanks guns1nger, that does exactly what I want it to do.
  5. Note to self: Update your version of DLP...
    (mine doesn't have that option )
    Cheers, Jim
    My DVDLab Guides
  1. Replies: 3
    Last Post: 26th Mar 2011, 08:21
  2. DVD Lab Pro Menu Resolutions
    By Jeff B in forum Authoring (DVD)
    Last Post: 6th Dec 2010, 17:11
  3. DVD Lab Pro menu help
    By stantheman1976 in forum Authoring (DVD)
    Last Post: 27th Jan 2009, 17:27
  4. DVD-Lab pro menu problem
    By wackman in forum Authoring (DVD)
    Last Post: 26th Aug 2008, 04:52
  5. multi menus (in DVD LAB PRO 2) with different formats/Button issues
    By dblue in forum Newbie / General discussions
    Last Post: 18th Oct 2007, 18:10
