VideoHelp.com Forum
Results 1 to 10 of 10
  1. I'm in the mood to replace my Toshiba SD-M1502 because of the infamous 2x rip speed limitation. Which drive is considered the current de-facto in speed and stuff? I want to get the best. I've heard a lot about LiteOn, should I go with them? If you could quote some specific model numbers, that would be great. Tray-loading would be best, I hate slot loaders. Thanks a bunch.
    Cromas
    <font size=-1>[ This Message was edited by: Cromas on 2001-12-16 15:52:23 ]</font>
  2. Lite-On = tawain made.....good shit for cheap...
    the pioneer dvd-roms are also good and cheap too....
  3. There are a lot of 'current' Pioneer models - 5 or 6 when I checked - which would you recommend? I haven't checked on LiteOn but I'm sure there's more than one.
  4. Cromas, 16X sounds pretty good...
    i have a samsung/compaq 12X dvd-rom i got awhile ago....works great...usually rips around 5-6X...
    so...16X should theoretically have a faster rip speed.....of course toshibas (and philips) suck...so that may not be the case....
    pioneer and lite-on are prolly the best bargains right now...so go with those....
    i think both brands' 16X models sell for around $40....check out http://www.newegg.com
  5. Defenetly go either with Pioneer or Lite-On! check PriceWatch for prices, you can propably get the Pioneer for around 60$
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    unfortunatly Dell ships Toshiba DVD-Roms.
    I've ripped at 8x burst speed.
  7. Greg12, not to doubt you or anything, but could you post a pic with that rip speed using a Toshiba ? i've got an Asus with a Toshiba DVD drive, and the max it ever came to was 2.3x
    Best Regards,
    Sefy Levy,
  8. Same here - ASUS with a toshiba 16x, I max out at exactly 2.0x, and 1.0x if I am not using DMA.
    Maybe he's talking about DAE, not dvd ripping? That would seem like a normal speed without DMA for DAE on this drive.
    <font size=-1>[ This Message was edited by: Cromas on 2001-12-17 19:49:39 ]</font>
  9. burst speed could be the initial speed...then it starts coming down really fast...
  1. CD-ROM vs. DVD-ROM
    By Judson in forum Mac
    Last Post: 6th Apr 2012, 08:33
  2. The fastest way for converting a DVD into AVI
    By Menvedao in forum Video Conversion
    Last Post: 23rd Jul 2009, 11:06
  3. Camera to DVD. Fastest way possible?
    By slaak in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 21st Jan 2009, 01:55
  4. Fastest from captured video to dvd?
    By larrym in forum Newbie / General discussions
    Last Post: 14th Jul 2008, 07:03
  5. Fastest AVI to DVD program
    By mjaeson in forum Authoring (DVD)
    Last Post: 18th May 2007, 05:09
