VideoHelp.com Forum
  1. Ive tried dvd shrink and tmpg dvd author.When the dvd video files are cut and joined its not perfect.
    What other software are available which will cut the frame accurate.
    Is the womble mpeg video wizard any better.
  2. Member jeanl's Avatar
    What do you mean, "not perfect"?
    jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
  3. Member Soopafresh's Avatar
    Frame Accurate ? TMPGEncMpegEditor . It's good, but it is slow.
    Give VideoReDo a try. They have a free eval period.
  5. Cuttermaran. But it requires elementary streams...
  6. Member daamon's Avatar
    I think the Womble MPEG Video Wizard will do the job too. I've not used it, just recall seeing that here somewhere...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    MPEG Video Wizard (not free) is frame-accurate. So is VideoRedo (no free), but many people have reported problems with video/audio sync. Many have reported that TMPGEnc's MPEG editor (not free) suits them fine, but others say it lacks enough features.
    The above three programs (plus Cuttermaran) are your apparent best choices. I've used all, and settled on MPEG Video Wizard because it suits my particular needs. I also have, but don't use, Womble's MPEG-VCR (the predecessor to MPEG Video Wizard) because of its clumsiness.
    In the end, you should evaluate each of these programs before you decide if one of them will do what you want. Hopefully, you won't just rely on opinions on this board, but actually put the evaluation copies of these programs through their paces.
    You're never alone with schizophrenia.
  1. Frame accurate cutting of H.264 files
    By Ahari in forum Newbie / General discussions
    Last Post: 30th Apr 2012, 04:33
  2. Suggest a Fast h264 Viewer which is Frame Accurate
    By holygamer in forum Authoring (Blu-ray)
    Last Post: 3rd Apr 2012, 19:10
  3. Frame accurate cutting on m2ts files?
    By stryker412 in forum Editing
    Last Post: 29th Jan 2012, 04:20
  4. Frame accurate WMV edits
    By jbeezer in forum Editing
    Last Post: 5th Jul 2010, 14:41
  5. Replies: 4
    Last Post: 23rd Aug 2008, 05:54
