I have some avi´s that i watch very well on my pc,i see the subtitles well,but the problem is that when i try to convert to DVD using Nero the subtutles do not show up....This only happens in some movies,I don´t now why???![]()
Can some one explain me why does this happens or anything i can do??
One more thing i now that Nero has the possibilite of join the 2 avi´s during the convertation,but my is not selectable,do i have to get anythingh more for my nero or this is not availabel at all.
Tanks..
Results 1 to 9 of 9
Thread: No Subtitles
what kind of subs? an avi with .srt subs? have you installed vsfilter?
Well, don't use Nero for AVI to DVD converisions. It has never, and will never be, the best (or even the 100th best) way, one source AVi or more...
/Mats
Yes SRT. ,i have ffdshow i thing is the same???Originally Posted by Baldrick
do you see the subs when you play the avi with media player?
or use something else than nerovision express like diko,thefilmmachine,avi2dvd,dvdsanta,winavi and you can add the srt subs.
Yes i normaly use Bsplayer,never tried media player,Originally Posted by Baldrick
Wich of this ones is themost simple(join avi´s and subtitles) i don´t want to do anything else,just simple DVD.
Thanks for all the advise
I think BSPlayer might have built in subtitle support.
BSPlayer does have built in subtitle support. It will display subtitle which is in a same folder as a movie.
ejmoreno,
you say that you want a simple DVD with subtitles using NeroVision Express and that you do have ffdshow. OK, use this guide to enable subtitles in ffdshow:
http://www.videohelp.com/guides.php?guideid=262#262
Note that your movie and your subtitle must have the same name.
You can play with ffdshow subtitle settings to change the font, color and position.
Now you should be able to convert your avi's with NVE with permanent subtitles.
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
how to make permanent subtitles for rmvb with srt subtitles using ffdshow?
By Nokiamania in forum SubtitleReplies: 1Last Post: 16th Oct 2006, 10:08 -
avi 2 mpg with subtitles = strange colors and no subtitles¿
By SidDan in forum EditingReplies: 0Last Post: 28th Mar 2002, 06:27
Newest guidesLatest tool updatesNew media commentsReplay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
