VideoHelp.com Forum
  1. I've got about 20 one second clips in AVI I want to join to process as one video. Is there a simple way to go about this?
    AVISynth is an option.
    Create a script with...
    AVISource("Filepath\Filename01.avi")+AVISource("Fi lepath\Filename02.avi")
    etc...
    BTW, it might be DirectShowSource() ...
    With same parameters...
    Replace Filepath with the path to the AVI
    Replace Filenamexx.avi with the name of the avi
  3. VH Veteran jimmalenko's Avatar
    Virtualdub is the easiest IMO. Either open your file and then go to File > Append AVI segment, or alternatively rename your files file_01.avi, file_02.avi ... and so on, then tick the "Automatically load linked segments" tickbox when you go to open your first file, and all the files in the sequence should load.
    If in doubt, Google it.
  1. Replies: 9
    Last Post: 3rd Jun 2010, 18:21
  2. Simple question....... what is the best way to join AVI files
    By True Colors in forum Newbie / General discussions
    Last Post: 24th Apr 2010, 21:22
  3. Replies: 32
    Last Post: 1st Oct 2009, 07:29
  4. Replies: 6
    Last Post: 8th Sep 2007, 02:59
  5. Replies: 1
    Last Post: 26th Jun 2007, 08:16
