VideoHelp.com Forum
    After reading quite a few complaints aboutthe Philips DVP 642 failing after about 6 months, I am looking for a potential new choice for a new player.
    I would like to have..
    PAL/NTSC conversion.
    Plays CDR/CDRW
    Plays DVD-R(W)/DVD+R(W).
    Plays MP3s.
    VCD,SVCD. Xvid is a bonus.
    Progressive scan.
    Dolby Digital and DTS capable.
    More than 8x FF and RW.
    I tried the search feature for DVD players, but I would appreciate more direct feedback from you guys...
    Thanks..
    NEC 3500AG - Firmware 2.TG
    LiteOn 16P9S - Firmware FS09
    Taiyo Yuden 8X, FujiFilm 8X YUDEN000T02, Phillips 8X CMC MAG-E01-000.
    DVDDecrypter, DVDShrink, DVDFab, Nero 7
    Hauppage WinTV PVR 150
    Dscaler, TMPGEnc Plus/Author, Canopus ProCoder, CCE.
  2. Member Krispy Kritter's Avatar
    Most players can handle what you want.
    Most people get the 642 because it is capable of playing mpeg1/mpeg2/divx/xvid and some asf/wmv on the fly without burning media to meet VCD/SCVD/DVD spec. Just put the files on a disc as data and play. Also, my original 642 (I have 2) is almost 2 years old now. They tend to get very warm, so the key is to keep them in the open as much as possible and don't set things on top of them.
    Google is your Friend
  3. Banned
    I just picked myself up an LG LDA-530 on Wednesday and I have yet to find anything it WON'T play - it even plays XviD w/6ch AC3 audio! I've read that alot of people consider the Phillips 642 and the LG LDA-530 similar feature-wise, and it's dirt cheap too.
    I chose the LG over the Phillips because the 642 I tested some of my XviD's on @ the store produced vertical lines that I wasn't impressed with, that and the LG was $10 cheaper
  4. Member craiggus365's Avatar
    I have 2 philips 642 for over a year now. Heat, yes! Problems, No - just keep it cool and you should be ok
    "Quit Playing With The Clock..."
    Rudy - Funhouse pinball game
    Guys.. thanks for your responses...
    The LG unit seems to be going for a higher price than the Philips...so I am leaning twords the Philips 642. But one more question - does the Philips 642 handle DTS audio??
  6. Member MJA's Avatar
    Avoid Philips at any cost
    The Philips player is nothing but garbage. The problem with the player is more than heat.anyways .I found this one at onecall.com PioneerDV588AS Progressive Scan DVD/ Divx player with SACD and DVD-Audio Playback http://ww1.onecall.com/PID_27949.htm $129 .
    I been using VSO DivXtoDVD Converter so no need for divx player
    http://www.download.com/VSO-DivXtoDVD-Converter/3000-7970_4-10376028.html?tag=lst-0-22
    Thank you for your post, but the Pioneer unit does not appear to have a PAL/NTSC converter.
  8. Member Krispy Kritter's Avatar
    yes the 642 can read DTS
  1. Region-Free DVD Player Recommendations?
    By D.V. Dee in forum DVD & Blu-ray Players
    Last Post: 20th Dec 2010, 17:10
  2. DVD Player Recommendations
    By DJBHUD in forum Newbie / General discussions
    Last Post: 26th Nov 2010, 10:47
  3. Replies: 0
    Last Post: 13th Jan 2010, 08:29
  4. Recommendations for DVD player =<$60
    By Lionblade in forum DVD & Blu-ray Players
    Last Post: 10th Feb 2009, 14:38
  5. upconverter dvd player/recorder recommendations...
    By rubberman in forum DVD & Blu-ray Recorders
    Last Post: 15th Jul 2007, 15:36
