VideoHelp.com Forum
Results 1 to 9 of 9
    I remmember reading that for a 700mb data cd you can fit 850mb of video on it, is it possible to fit more then 4.7gb on a 4.7gb dvd?
  2. VH Veteran jimmalenko's Avatar
    http://www.videohelp.com/faq#740
    http://www.videohelp.com/dvd.htm#1000
    AFAIK you can't get much more than 4482MB (4.38GB) onto a SL DVD-R. I *think* there's a difference of about 7MB with SL DVD+Rs.
    If in doubt, Google it.
  3. Member waheed's Avatar
    Max is 4.37GB
    Theres a clever marketing scheme used here. In the computer world 1024 Kbytes is actually 1000 Kbytes(used by companies). so:
    1000 = 1024
    1000 x 1000 x 1000 = 1024 x 1024 x 1024
    1GB = 1.0737 GB
    Therefore
    4.7GB/1.0737 = 4.377GB
    Which means 4.7GB used by companies is actually 4.37GB in the computer world.
  4. Member pbhalerao's Avatar
    Waheed's statement is correct. This is true of not only DVD media but also of Hard Disks. For example an HDD sold as 120GB in the shops actually results in a formatted capacity 114.44 GB. If you go back to the store and ask why a "tongue-in-cheek" service person may tell you that 'formating will take away some of the diskspace for use by the OS'.
    *** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
  5. Banned
    Floppies and flash media too . . .
  6. Interesting, only CD seems to be correct
  7. Member thevoelk's Avatar
    Keep in mimd, CDs use a 14 bit code. It's called Extended Numerical Format. It has to do with the pits and lands, where you can't have two 1's or 0's next to each other (I can't remember which) since the bit is actually the transition from a land to a pit, not the pit/land itself.
    Not really. A CD can hold more than it tells you using an alternate writing mode not commonly used.
  9. Member waheed's Avatar
    True. For example, a 700MB CD can hold 800MB of video in VCD format.
  1. Replies: 6
    Last Post: 6th Nov 2009, 04:54
  2. Color space question
    By mourya in forum Programming
    Last Post: 22nd Dec 2008, 19:08
  3. Does lowering the maximum bitrate, gain more space?
    By Wile_E in forum Authoring (DVD)
    Last Post: 23rd Oct 2007, 20:37
  4. Replies: 6
    Last Post: 14th Jul 2007, 19:55
