Hello, I have created a home movie DVD and noticed the quality isn't that great. If I trace my steps back and review the process in making this video, I noticed it was when I converted the file to MPG from AVI that I lost the quality. Is there anyway to use an AVI file in DVD LAB (Which is what I'm using to make the DVD). If not, how can I go about getting the best quality. I have an AVI to work with and want to output to a DVD. Thanks.
Thread: Loss of quality
Can you be any more vague ?
I would suggest using good quality MPG2 converters such as TMPGEnc, Canopus, MainConcept, etc. More info is available in Tools section.
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
you probably encoded the avi to mpg using too low a bit rate thus the lower than original quality. If you are not careful in your settings you will always end up with a lesser quality MPG2. As was stated previously, get yourself a good quality encoder and read the guides as there are tons of settings to learn.
No DVD can withstand the power of DVDShrink along with AnyDVD!
What are you using to convert to mpeg, what's your source file properties and what is the mpeg properties that your converting too.
How about this:Originally Posted by Soopafresh
I have a file I want to put on this disk. How do I go about doing this?
Vague enough.
What is your source file. Is it DV, is it merely tagged with .avi and it is actually an Xvid/Divx/MP4...etc.... Without knowing the source, you really can't ascertain what type of result you should expect. If it is an uncompressed AVI file take from DV footage, I'd imagine your encoder's bitrate is too low. Otherwise, I'm going to assume your source is not that great to begin with.
Quality loss from D V -AVI to other formats
By santolina in forum Video ConversionReplies: 20Last Post: 24th Jul 2009, 14:24 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 14:56 -
MKV to AVI without quality loss
By Markomaani in forum Video ConversionReplies: 10Last Post: 15th May 2009, 09:51 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 01:03
