If I want to post a short 15-30 second video clip on a website what is the best format to use? Original video would be in mpeg2 format recorded on a dvd camcorder.
Thread: Video files for a website
A lot will depend on how your wesite will be accessed generally. Broadband or dial-up. How much space on the server. What quality will be acceptable to you or your users.
People are ripping whole DVDs and putting them on sites for others to download. And people are downloading.
So you have to judge yourself.When I was born I was so shocked that I could'nt speak for 18 months.
Since nearly everyone has MS's player wmv is probably your best bet, it also conveniently launches the player for you if you use a link. It can also esily be embedded right in the page. It also provides a very high compression at a very low file size........
What bitrate size etc to use as mentioed above depends on your target audience. You could always provide multiple files for different connection speeds.
Thanks. What software do I use to create a wmv file from mpeg? Did a search for guides for mpg to wav in convert but nothing comes up.
play H.264 MP4 files in website
By brunovt in forum ProgrammingReplies: 2Last Post: 18th Jan 2012, 12:31 -
Trying to convert MTS files to something reasonable for website
By Newmomma in forum Video StreamingReplies: 5Last Post: 30th Jan 2011, 11:52 -
Breaking up DVD into downloadable files for website?
By Jinkies in forum Newbie / General discussionsReplies: 2Last Post: 19th Sep 2008, 08:50 -
Where are these files from website being loaded?
By brassplyer in forum Video StreamingReplies: 3Last Post: 28th May 2008, 21:11 -
Split video files for website
By wrcousert in forum Video ConversionReplies: 2Last Post: 22nd Apr 2008, 17:42
