I want to try the DVD Rebuilder. But there are two choices, the DVD Rebuilder 0.93 beta and DVD Rebuilder 0.82.1 at
http://www.free-codecs.com/DVD_Rebuilder_download.htm
What’s difference between them and how to use it? Thanks.
Thread: Which of the DVD Rebuilder?
the one that says it's beta.. coz its betta than the other one
The electronic components of the power part adopted a lot of Rubycons.
They are both beta versions. One is newer than the other. I believe the 0.82.1 release is the last release before a few major changes took place. The 0.93 beta is the current freeware release. I use 0.93 without problems, and would suggest that is the one you should download.
Is the DVD RB guide available online?
http://forum.doom9.org/forumdisplay....2b972ae20&f=75Originally Posted by coody
check out the DVD RB forum at doom 9.
DVD Rebuilder overflow
By RickyPinxt in forum Video ConversionReplies: 14Last Post: 27th Apr 2011, 14:43 -
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum User guidesReplies: 2Last Post: 20th Jul 2009, 12:31 -
DVD Rebuilder (free)
By maja_the_bee in forum DVD RippingReplies: 1Last Post: 27th Jul 2008, 10:12 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
