  1. I've taken some film footage.
    I used a professional camcorder with a professional boom mic.
    I've tried some simple video editing software (Ulead) to increase the sound.
    Unfortunately, this results in a lot of hissing and other background sounds.
    I've borrowed someone elses PC and have Adobe Premiere and Audition at my disposal.
    (I've never used either software before.)
    Can someone tell me how I can fix the sound and not have the hissing and noisy background?
    Thanks.
    Jam
    You can try using some of the filters in Audition, such as HISS REMOVAL, or general NOISE REMOVAL after you amplify the audio, but generally, you are starting with a low SIGNAL to NOISE ratio source, so your results may not be that good.
    More the reason to perform a sound check before you begin recording (remember this next time!).
    I've used these filters on captured vinyl recordings to remove the pops and clicks, plus the low level hiss and the results have been quite impressive - but my S/N ratio was probably a lot higher than yours to begin with.
    ICBM target coordinates:
    26° 14' 7.62"N
    80° 16' 0.78"W
    I use Cool Edit. Have for years. Easy to learn too.
    Just open the audio file (after you exported from premiere or what else you may be using , make sure you are in waveform view and highlight the areas you want to add effect to and then choose an effect from effects on the menu.
    Premiere Pro will export to a lot of formats.
  1. Increasing the sound
    By Jomapil in forum Newbie / General discussions
    Last Post: 3rd Feb 2009, 08:51
  2. Desperate Times Give Desperate Prices
    By marquis6461 in forum DVD Recorders
    Last Post: 30th Jan 2005, 19:58
  3. Increasing sound level
    By marcopolo1 in forum Audio
    Last Post: 9th Mar 2004, 11:06
  4. Increasing sound in ATI All-In-Wonder 7500
    By cypherwolf in forum Capturing
    Last Post: 28th Aug 2002, 14:16
  5. increasing sound volume
    By now3d in forum Video Conversion
    Last Post: 1st Jan 2002, 05:33
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
