Hi,
I use Internet Explorer with Virtual Machine and I use Netscape for
Java Sun. I am not able to copy, hightlight, or paste with Virtual
Machince or Java Sun. What java program allows copying, pasting, and
highlighting and/or is there a program that would enable java sun
and/or virtual machine to copy, past, and hightlight? Please and
thank you.
Results 1 to 9 of 9
Copy, Paste & Highlight what exactly ?
The text displayed on websites ?
Images ?
More info please
If in doubt, Google it.
Hi,
I missed that. t hanks for pointing it out to me. Text? Please and thank you.
I run Internet Explorer with Virtual Machine and generally have no problems whatsoever highlighting text using my mouse, then hitting Ctrl-C, then opening Word and pressing Ctrl-V. The one exception that wouldn't work this way has been LS's site
which I ended up finding a way around anyway
I don't think it has anything to do with Java ?
Hi,
You are able to hightlight copy and paste text within java virtual machine? Pleae and thank you. All the java sites I have ever tried do not work for that. What version of virtual machine are you useing and/or is there special options need to be picked to enable? Please and thank you.
I don't get what you mean by "within java virtual machine". All the virtual machine does is compile the java code. an you give an example of a webpage you are trying to copy the text from and can't ?
Games. com, yahoo games, gamedesire, pogo, ... I am learning how to host tourneys, and created a place for it also anyway those sites uses java and I am not able to copy, highlight, or paste for any of those sites and other java sites also same thing?
So you're trying to copy the Java Applets then ?
Hi,
Thanks for helping me I really appreciate it. I need to give more information in what I want. thanks for helping me. Like if I go to yahoo games and play pinochle and somone gives me a web site there I am not able to figure out how to highlight it and copy it. That would be called java applets then?
Stream MPEG2 file in JAVA
By PCNG in forum ProgrammingReplies: 1Last Post: 6th Oct 2011, 04:16 -
Java looking very murky and unfocused
By johns0 in forum ComputerReplies: 2Last Post: 4th Mar 2011, 02:40 -
ProjectX Java error
By kimse in forum EditingReplies: 8Last Post: 14th Sep 2008, 16:44 -
question about java download
By jimdagys in forum ComputerReplies: 7Last Post: 5th Oct 2007, 05:48 -
Java
By Lucifers_Ghost in forum ComputerReplies: 2Last Post: 1st Jun 2007, 09:27
