VideoHelp.com Forum
Results 1 to 10 of 10
  1. My friend has some home videos (still on the special camcorder tapes) that he wants to backup on his computer. His video card is a Geforce 6800 128MB DDR 256bit Dual DVI. I know that generally ATI All-In-Wonder is what is usually supported, so I don't know where to turn. He's willing to buy software, but free isn't ruled out . Thanks.
    "The real hero is always a hero by mistake; he dreams of being an honest coward like everybody else." -Umberto Eco
  2. Member edDV's Avatar
    What format are the camcorder tapes?
  3. Originally Posted by edDV
    They're (analog) NTSC 30Hz AFAIK. For some reason my friend was thinking the camcorder was digital, but I thought since it's 3-4 years old and uses tapes that it isn't.
  4. Originally Posted by AuroEdge
    Digital 8 has been around for longer than that and they record to tape. Look on the cam. If it's a digital 8 then all you need is a firewire card and a firewire cable for capture.
    Don't confuse digital 8 with hi-8 which is analog, don't look at the tapes but the cam as they use the same ones.
  5. Originally Posted by thecoalman
    Assuming it's Digital-8 (it's a Sony camcorder), what software do I use to capture on Windows with firewire?
  6. Any really, you can even use Windows Movie Maker. there's other listed in the tools section. You don't capture but transfer digital video. It's lossless, almost like copying a file from one folder to another.
    If it's analog though it's a whole other ballgame. :P
    Once on the computer you still need to convert to MPEG2 and author it to disc.
  7. Give WinDV a try. It's free
  8. Originally Posted by thecoalman
    Just to elaborate a little more, if it's digital and he wants to backup the "captured" file it will require about 1 regular 4.7 GB per 20 minutes roughly.
    That's why they use tape, currently it has the highest capacity at the cheapest price. It can be converted to mpeg2 at a slight loss in quality allowing you to fit about 1 hour or more per DVD and will need to be if you want to view on a standalone DVD player.
  9. Originally Posted by thecoalman
    That's why they use tape, currently it has the highest capacity at the cheapest price. It can be converted to mpeg2 at a slight loss in quality and will need to be if you want to view on a standalone DVD player.
    Can TMPGEnc convert to mpeg2 adequately?
  10. Originally Posted by AuroEdge
    I don't use it myself but many others do.... It's one of the prefferred encoders here. That only converts the video though, you still need an authoring app if you want to play it on most standalone DVD players. Some will play just a regular file burned to DVD but there are not very many. :P
  1. Capturing software
    By sruddy in forum Capturing
    Last Post: 7th Feb 2011, 13:53
  2. capturing software
    By fabpozzi in forum Capturing
    Last Post: 23rd Oct 2009, 07:04
  3. Use a software codec when capturing with an ADVC300?
    By timothyd_1975 in forum Capturing
    Last Post: 15th Jun 2009, 23:06
  4. Replies: 22
    Last Post: 28th Feb 2008, 15:38
  5. best video capturing software?
    By majax79 in forum Newbie / General discussions
    Last Post: 3rd Jan 2008, 15:40
