VideoHelp.com Forum
  1. I just did a small video record on my digital camera, I believe its wm format noe sure. I was just wondering if anyone knows of an program that allows you to convert it to a WMA format. I am unable to play it.
    Any Idea's would be great thanks.
    EE
  2. Member daamon's Avatar
    Hi e40water,
    When you say "digital camera", I'm guessing you mean a stills / photograph camera and not a video camera...
    If so, the format might be Quicktime's Movie (filename.mov) - some are.
    You say you can't play it - I'm guessing that you're talking about on your PC (or MAC). You might not have the codec for it. What happens when you try to play it?
    I'm doing a lot of guessing and asking questions - we need more info...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Yes I am thinking the format might be Quicktime's Movie (filename.mov). Is what I need to play this one on my pc. Its basically a video mode, On my digital camera, Its not still pic's. I guess I need to get Quicktime's? Another question, Am I able to convert this file to dif format?
    thanks for youre anwsers & replys. =)
    EE
  4. Member daamon's Avatar
    To play .mov files, you need the Quicktime player. Easily found (I guess) if you do a Google search... It might even be on this site's "Tools" list.
    Yes, I believe you can convert MOV files to other formats - not sure which formats, and which tools are available.
    Look under "How To... Convert" to the left.
    Glad to help.
    Carpe diem.
  5. Member dcsos's Avatar
    the deluxe method is to use quicktime directly for the conversion.
    If you have quicktime installed, paying $20.00 to www.apple.com
    will unlock features already present but unavailable in the installed player
    this will allow handy conversion through either SAVE AS or EXPORT
    become usable in QUICKTIME PRO
  6. The two most common formats those digital cameras record in can be played by either Windows Media player or Quicktime depending on what it's recoreding in. Both are free if you only want to view the video.
    As for converting I've had a little experience with this, a lot of frustration. The first problem is they use a very odd framerate which seems to vary depending on the model, but basically is around the 10 fps area. One of the issues I ran into is my editor appeared to load the entire clip into memory for editing and converting... if you want to convert I'd look into tools available from whoever owns the format as suggested above.
  7. Awsome guys thats the anwsers I was looking for.
    thanks again for youre guys help.
    EE
  1. Digital Frames / Video Playback?
    By therock003 in forum Portable Video
    Last Post: 24th Jun 2009, 11:13
  2. Replies: 12
    Last Post: 16th May 2009, 01:03
  3. Cant Live Playback with sound from DV Cam into PC via firewire.
    By Drakh in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Dec 2007, 12:48
  4. How to convert Digital Cam AVI to Xvid or Divx?
    By Newbie_here in forum Newbie / General discussions
    Last Post: 16th Sep 2007, 01:48
  5. Another Question Regarding Digital Video Stabilizers
    By tlcmd in forum Newbie / General discussions
    Last Post: 28th Aug 2007, 15:39
