i have a mkv file which about 25 mins, I used mkvextractgui to extrac the avi and acc file so i can convert it to avi, but the avi file is only 19 mins and the aac files is 25, now everything is out of sync i can't put the avi and the acc together. can anyone help
Thread: problem with mkvextractgui
Sounds like the mkv contains VFR (Variable FrameRate) video. When you assume that the video is CFR like that then it is not supposed to sync.
Been a few posts lately on VFR MKV's, so you might want to try searching.
you could try mkv2vfr from http://haali.cs.msu.ru/mkv/.
It is a command line tool, open a command prompt and type
"c:\location to\mk2vfr.exe" "c:\video.mkv" "c:\video.avi" "c:\video.vfr"
MKVExtractGUI-2 vs MKVToolnix
By jandor2009 in forum Video ConversionReplies: 7Last Post: 6th Jan 2012, 19:06 -
Using MKVExtractGUI-2 batch tool
By CasanovaFly in forum Video ConversionReplies: 4Last Post: 2nd Jan 2011, 10:05 -
Having Problems with MKVextractGUI
By PlissandrO in forum SubtitleReplies: 2Last Post: 30th Sep 2009, 04:50 -
mkvextractgui with AVC problem
By Szymus in forum Video ConversionReplies: 2Last Post: 2nd Feb 2009, 13:36 -
An issue with MKVExtractGUI
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2008, 02:32
Statistics
Newest guides
Latest tool updates
New media comments
