Ok I have a bunch of problems.
First and probably most important for some reason all of a sudden my computer it not recognizing any subtitle files. No movie player will recognize any subtitle track?
fmpegX 0.0.9s gives me the error code
“The installation was not successful.
##cp: / Library/ Application support/ ffmpegX/ mpeg2enc: No such file or directory”
And every time I open the application it makes me find the path again for mencoder, mpeg2enc and mplayer
When I try to join two AVI’s together I end up with no audio. Any help will be most appreciated.
When I open an .str file with VLC I get the error
“main: demux doesn't like DEMUX_GET_TIME”
What do you think that means? I have tried playing my joined AVI’s with every player I can think of and I have somehow when I join them together I have lost the audio?
It means VLC won’t play .srt subtitle files by itself. If you want the subs to load, make it a similar name for auto-detection, or use the Open File dialog box (not the default Quick Open File). Then you may select a subs track from the Video menu, while the AVI is playing.Originally Posted by skyechester
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Snyc problem with srt file embedding into AVI
By applemac01 in forum SubtitleReplies: 0Last Post: 24th Sep 2009, 10:04 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 15:44 -
Joining avi's - problem with differing bitrates
By Topher5000 in forum EditingReplies: 6Last Post: 12th Aug 2007, 20:54 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 22:00
Statistics
Newest guides
Latest tool updates
New media comments
