hey guys i have just downloaded the firmware updat of 0112,now i am using easy cd creator to burn disc and have read the manual for how to burn the .rom files.I have went to file then cd-layout options,changed file system to iso9660 as described to do but do i als change file system part from Any MS-DOS 8.3 character file names and click on the ISO-9660 8.3 character file names option? I also noticed there are 3 .rom files so do i just burn them all to the cd?
Unless you want/need the subtitle information changed...there is no need to update. Nothing else was corrected/changed.
Google is your Friend
I'm not sure about using Easy CD creator, but if I remember, you have to change something to "File sysem 2" which allows for longer filenames. And yes you need to burn all three files to the CD. Your dvd player will need one of these files and will choose the specific file for your version. Since you don't know which one you need, you have to burn all 3 files to CD.
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
New firmware v.0112 for Philips dvp630 (AKA dvp642 in usa)
By etab in forum DVD & Blu-ray PlayersReplies: 27Last Post: 14th Jan 2009, 09:58 -
Panasonic Firmware question
By vetski179 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 19:30 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 06:56
Statistics
Newest guides
Latest tool updates
New media comments
