Title says it all
I tried...fine to mpg...but no sound. Authored using TMP Genc DVD author
but my standalone dvd player came up with an error message...
A 358 meg file came to 4 gigs...is this normal?
How much space is required on DVD disk to author?
Thanks all
Yes, tmpgenc supports xvid. Change the video bitrate or use the wizard to get the output size you want.
If no audio read www.videohelp.com/tmpgenc#problems
Thanks Baldrick
Did read somewhere that TMP Gencs own encoding for sound isnt as good as it could be..
TMPGEnc has a reputation for poor audio encoding, but it works fine for me and I have never noticed any quality problems. I'm sure the members here can point you to better audio encoders.
But unless your XVID has very high quality audio to start with I doubt you will notice the difference.
Your audio problem may relate to AC3 audio. TMPGEnc doesn't like it. Same with MP3 VBR audio.
The usual system is to strip out the audio with a program like VirtualDub and save it as a WAV audio file. Then input that as your audio source to TMPGEnc. That can give you MPEG-1 Layer2 audio.
If you want the better and more compliant AC3 audio, you can use an external encoder or with TMPGEnc DVD Author there is a plug in AC3 encoder.
For menus, etc., I leave about 200MB free using TDA. The size of your file depends on the runtime of the video and bitrate used to encode. I don't do much with HDTV, but it would be similar. There are bitrate calculators in 'Tools' to the left that should give you an idea what the finished file size will be.
All great info...
Thanks guys
tmpgenc has now pretty good audio encoding in the later versions .. plus you can use external programs anyway
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
Best Method of IVTC to use In Converting HDTV .mpg to xvid
By onesikgypo in forum DVB / HDTVReplies: 7Last Post: 30th Sep 2009, 00:13 -
mpg to avi(xvid) problem
By okman in forum Video ConversionReplies: 4Last Post: 6th Jun 2009, 05:00 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Convert 1080i .mpg to hr.hdtv (960x540 xvid)
By MrFingers in forum DVB / HDTVReplies: 4Last Post: 6th Aug 2007, 09:00
