Hi All,
tis been a long time since I was last here, bought myself a Sony DVD Handycam and now need all the help I can get!![]()
Basically I opted out of spending the extra £150 for the next model up with DVout as I though hey, I've got a DVD ROM and DVD Writer so editing shouldn't be a problem! Boy was I wrong!!!![]()
I've tried many programs to find one that will edit Vobs and have only found the one but It doesn't import DVD menus created in Photoshop CS.
So that brings me to one question, I have looked but have not found a definitave answer. If I convert my VOBs, to M2v and Audio is there any loss in video quality and also If i "Faked the file to an AVI" with a prog such as VFAPI is there any Loss of Video,
I know my camera captures sound in AC3 so I also have to be able to work with that.
Some please tell me there is an App I can just dump my VOBs into for editing, I'm not really looking at editing per se but more cutting and chopping, but want to incorporate a DVD menu created in Photoshop.
Many Thanks in Advance!
Ryan
No quality loss, you just separate the audio and video to separate files.Originally Posted by ryan woo
If you want to do editing and keep the quality(no reconverting at all) you can only cut and join, you can use mpeg-vcr, videoredo, cuttermaran, tmpgenc mpeg editor. See our tools section under Basic video editor MPG.
If you want some advanced editing use mpeg video wizard, it only reconverts the parts that needs converting like if you add transistions or such.
Baldrick, you the man, I'll try some of those as soon as I get the chance!
editing or converting 24fps mpg and retain original length and playback
By MisterRPH in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2011, 22:36 -
BD --> DVD (SD) How to retain both, DTS and AC3?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2010, 17:28 -
How to retain 16:9 when converting to Huffyuv?
By brassplyer in forum EditingReplies: 3Last Post: 25th Apr 2010, 07:15 -
Is it possible to retain HD Audio when converting to BD9 in BDREBUILDER
By igotafeelin in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Aug 2009, 15:42 -
Create DVD from mkv and retain size?
By elven in forum Authoring (DVD)Replies: 1Last Post: 7th Apr 2008, 05:15
Statistics
Newest guides
Latest tool updates
New media comments
