VideoHelp.com Forum
  1. Member CBC's Avatar
    I'm working on a audio DVD project for a friend, converting a compilation of mp3s gathered over the years to wav files & buring to both DVD & CD-R.
    I've converted all the mp3s to wav, applied wavgain to them to normalize gain levels then used dbpoweramp to resample from 44.1 to 48hz to burn onto the DVD. I also burned the wav to CD-Rs as audio CD. But when playing them back, all the tracks sound "slowed down" on the CD-Rs.
    What caused this, & what can I do to fix? Does converting from 44.1 to 48 cause this? I'm stumped
  2. Member wulf109's Avatar
    CD audio should only be 44,100 sample rate.
  3. Member CBC's Avatar
    ok, so then re-sampling back down to 44.1 should fix? I can do that fairly easily w/ dbpoweramp. Thanks for your response.
    Yes, it will.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  5. But 44.1khz won't be dvd spec.
    When "converting" your mp3's to .wav, go directly to 48khz.
    Cheers, Jim
    My DVDLab Guides
    He's having problems with creating an audio CD, not a DVD. The standard for a CD is 44.1ksps.
  7. (DUH!)
    Note to self: Read everything twice, then open mouth, change feet.
    Cheers, Jim
    My DVDLab Guides
    ... Read everything twice...
    That takes too long!
  1. M2TS conversion and playback slower than Molasses in January
    By HighVoltageMiner in forum Video Conversion
    Last Post: 13th Jan 2010, 15:45
  2. Slower conversion with Windows 7?
    By gooberguy in forum Video Conversion
    Last Post: 3rd Nov 2009, 20:27
  3. audio conversion problems? (wav to ac3
    By just in forum Newbie / General discussions
    Last Post: 28th Oct 2008, 18:35
  4. Join 2 uncompressed wav audio files
    By kidcash in forum Audio
    Last Post: 11th May 2008, 02:15
  5. Audio problem with WAV files
    By vertical in forum Newbie / General discussions
    Last Post: 8th Jul 2007, 17:47
