Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 75
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    mencoder is very useful for converting between different container formats. It is a command line tool so it is not super easy to use for us lazy newbies.
    How to convert from OGM to AVI or MKV to AVI with mp3 audio and leave the video source intact.
    If the OGM or MKV already has a video that can be stored in AVI like DivX or XviD you only need to copy it. Use gspot to identify the video codec in the ogm,mkv.
    How to convert from OGM to AVI or MKV to AVI with mp3 audio and xvid video.
    If you want to convert the audio to mp3 and the video to xvid in an avi.
    Download mencoder for windows, http://www1.mplayerhq.hu/MPlayer/rel...32-1.0pre7.zip
    Extract all files to a folder on your hd.
    Open a Command prompt from Start->Accessories->Command prompt
    Type
    "C:\Program Files\mplayer\mencoder.exe" "c:\video\video.ogm" -oac mp3lame -ovc copy -o "c:\video\videooutput.avi"
    Explanation:
    "C:\Program Files\mplayer\mencoder"
    The location to the mencoder.exe
    The video ogm or mkv video source
    -oac mp3lame
    Convert the audio to mp3
    -ovc copy
    Copy the video, no reconverting
    Where to output the file and the new video name
    Hit enter to start converting
    Done!
    How to convert from OGM to AVI or MKV to AVI with mp3 audio and xvid video .
    Same as above but change the
    -ovc copy
    to
    -ovc xvid -xvidencopts pass=1
    so it will be
    "C:\Program Files\mplayer\mencoder.exe" "c:\video\video.ogm" -oac mp3lame -ovc xvid -xvidencopts pass=1 -o "c:\video\videooutput.avi"
    Explanation:
    Xvid video codec and one pass encoding
    You can also add video bitrate if you like,
    -ovc xvid -xvidencopts pass=1 bitrate=1000
  2. Member Soopafresh's Avatar
    Nice one ! I love command line utilities. Thanks.
    Here are a few questions with this:
    How do I use it for a file with multiple audio tracks?
    And just how big can the file you are converting can be?
    What are the commands that would allow me to launch or save it to a different drive?
    Thanks. I always come here for my conversion needs.
    No idea, it is probably possible but I haven't done that much mencoding.
    Adjust the bitrate, use a bitrate calculator to calculate.
    Change the drive letter, like d:\video.avi
    Use -aid # or -alang eng if it is tagged properly to specify which track to convert. The second track you would have to process seperatly like say.
    mplayer -aocm:file=track2.wav -vo null -vc dummy -aid 2 input.mkv
    To extract the 2nd stream, then use mencoder with -aid 1.
    Also use -lameencopts to change lame settings. -oac help for a list of audio compressors (pcm, ac3, etc.). -ovc help for a list of video codecs, including lossless ones.
    Check the docs over at mplayerhq for full details.
  6. Member rwmol's Avatar
    SimpleDivX uses mencoder for conversion. Only problem it converts 6 channel input to stereo. Is it possible to add a config file to the mplayer directory? If so. what would the command line be?
    How do I batch convert a whole lot of files with Mencoder?
    Hello, im sorry to bother but Im in a hurry to format my computer and am trying to get everything onto disk. Ive an OGM file thats just a bit too big and wont fit on the disk, and found your thread/guide to converting to AVI. I followed your instructions, but to no avail. It comes up saying Cant open output file "c:\video\videooutput.avi"
    Heres the log:
    C:\Documents and Settings\Molly>"C:\Program Files\mplayer\mencoder.exe" "C:\Docu
    ments and Settings\Molly\Desktop\ah.ogm" -oac mp3lame -ovc xvid -xvidencopts pas
    MEncoder 1.0pre7-3.4.2 (C) 2000-2005 MPlayer Team
    CPU: Intel Pentium 4/Xeon Willamette (Family: 8, Stepping: 2)
    Detected cache-line size is 64 bytes
    CPUflags: Type: 8 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
    Compiled with runtime CPU detection - WARNING - this is not optimal!
    To get best performance, recompile MPlayer with --disable-runtime-cpudetection.
    File not found: 'frameno.avi'
    Failed to open frameno.avi
    success: format: 0 data: 0x0 - 0x2bed0c75
    [Ogg] stream 0: video (FOURCC XVID), -vid 0
    [Ogg] stream 1: audio (format 0x2000), -aid 0
    [Ogg] stream 2: subtitles (SRT-like text subtitles), -sid 0
    Ogg file format detected.
    VIDEO: [XVID] 640x352 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:18 fourcc:0x44495658 size:640x352 fps:23.98 ftime:=0.0417
    Opening audio decoder: [liba52] AC3 decoding with liba52
    No accelerated IMDCT transform found
    [Ogg] Language for -sid 0 is '-slang "English[eng]"'
    AC3: 5.1 (3f+2r+lfe) 48000 Hz 448.0 kbit/s
    Using MMX optimized resampler
    AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
    Selected audio codec: [a52] afm:liba52 (AC3-liba52)
    Cannot open output file 'c:\video\videooutput.avi'.
    Exiting...
    If you have the time, please tell me if you notice any errors or something ive done wrong. I appreciate your time.
    *bump*
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    does the c:\video folder exists?? if not create it first or use some other folder.
    ya, I set up a c:\video folder, hell I even tried putting the video.ogm and videooutput.avi in there, maybe for something to overwrite, but didnt work at all.
    *bump*
    thankyou
    this works a lot better than Video Cleaner
    Thanks for the help in converting my mkv files into avis.
    I just have one little glitch. The subtitles were lost in the conversion. Is there anyway to keep the subtitles during the change over?
    Thanks.
    mplayer can demux subtitles by using say the -dumpsrtsub if they are textsubs or -dumpsub for vobsubs. See mplayer man for full details/options. Not sure if mencoder can mux subs to avi though and even if it could, external subs are more compatible anyway.
    Could also just demux the subs using mkvextract.
    Fabulous . .. thanks
    hi... i got prob wit mencoder.... i try to follow ur instruction to copy subtitles and i had this prob as shown below..
    C:\Documents and Settings\Used>"Desktop\mplayer\mencoder.exe" "c:\Program Files\
    BitComet\Downloads\school rumble1-2\[WF-KAA]_School_Rumble_02.DVD(XviD.AAC)[55F0
    8DB6].mkv" -oac mp3lame -ovc xvid -xvidencopts pass=1 -dumpsub -o "c:\Documents
    and Settings\Used\Desktop\test.avi"
    CPU: Intel Pentium 4/Xeon/Celeron Foster (Family: 8, Stepping: 7)
    dumpsub is not an MEncoder option
    can any1 help me???[/b]
  18. i am trying to use this method to convert an mkv to avi. the source uses the h264 video codec, and the audio is aac (i have both codecs installed). when i combine the video and audio streams into the avi, there is an error in the output file (frame 568). this glitch is not present in the source files, they play perfectly, while the output file crashes what ever player i use, as well as virtual dub when i attempt to put subtitles in it. does anyone know what might be causing this?
    Copying native AVC to an avi could be the problem. Not really a good idea at any rate. Does the mkv use native AVC or VfW compatibility mode? Also how are you testing playback? With mplayer or something else?
  20. the mkv is vfw mode. i'm copying the video stream and converting the audio to lame mp3 (i normally use virtual dub mod, but it doesn't support aac audio). i've tried playing the file in both real player and windows media player, as well as loading the file in virtual dub, all 3 result in a program crash when it gets to that particular frame. in media player, i get an error message saying that there is an assertion error in the C++ runtime library and gives the file path for the h264 codec in ffdshow. is it possibly a problem with ffdshow?
    Try playing it with mplayer.
    If the mkv uses VfW for the video (not recommended or spec compliant for AVC) then remuxing to avi should be fine.
    What build of ffdshow?
  22. it doesn't play in mplayer either. i tried another mkv with the same encoding on the streams and it behaves the same way. i'm using the 9/20/05 build of ffdshow.
  23. mencoder also crashes if i try to re-encode the video to xvid during the initial pass, however both the source mkv and the extracted avi stream (i used mkvextractgui for the extraction), which also use the h264 codec, playback with no problems in any player
  24. Member
    Try this build of mplayer/mencoder: http://ffdshow.faireal.net/mirror/mp...05.10.09.P4.7z
  25. Member
    how to add subtitles if i convert a dual file?I have problem with the subfont, please guide me.
    thanks in advanced
  26. Member
    try using a new mencoder GUI, which is alltoavi:
    http://alltoavi.sourceforge.net
    it converts ogm/mkv to avi using subtitle, has batch mode and subtitle/audio selection
  27. Member KIJIN's Avatar
    I've been using Mencoder coder for some time now, tho I only use its most basic of commands (ripped from this site ). Thanks for all the posts, BTW!
    So, this may sound stupid, but is lame's mp3 encoder its default audio encoder? Is there any other way to change the audio encode to like, say, good ol' wav.?
    KIJIN,
    Befuddled and confused
  28. Member
    audio codecs are selected using the flag -oac CODEC name, look on the manual of mencoder for a list of codecs
  29. Member
    Default I think from recollection was libavcodec 224k mp2. Now if you don't sepecify an audio codec, I think you will find it asks you to and won't encode.
    Sure for PCM (assuming that is what you meant by "good ol' wav") it is just -oac pcm.
    Errr, on second thought, I don't think it ever had a default audio encoder. You always had to specify one, just that if you do -oac lavc, you get 224k mp2.
  30. Member KIJIN's Avatar
    K. Got that part at least.
    Hope you guyz don't mind another question. I think (correct me if i'm wrong) that you can imbed subs on the avi file using mencoder. But I keep running into the same problem.
    C:\>"c:\mplayer\mencoder.exe" "c:\W1.ogm" -alang 0 -oac mp3lame -sub "c:\W1.srt"
    -ovc xvid -xvidencopts pass=1 -o "c:\W1.avi"
    It works fine, but then it indicates :
    [Ogg] Language for -sid 1 is '-slang "English[eng]"'
    VDec: vo config request - 640 x 480 (preferred csp: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    videocodec: XviD (640x480 fourcc=44495658 [XVID])
    xvid: par=0/0 (vga11), displayed=640x480, sampled=640x480
    xvid: 2Pass Rate Control -- 1st pass
    New_Face failed. Maybe the font path is wrong.
    Please supply the text font file (~/.mplayer/subfont.ttf).
    subtitle font: load_sub_face failed.
    The conversion works. But, no subs still.
    I didn't find a /font directory in the mplayer directory. Do you have to DL another specific true type font file for it to work? Or did I use the wrong command?
    Sorry to bother ya guyz.
    KIJIN,
  1. How to convert matroska MKV to AVI or OGM to AVI
    By Baldrick in forum User guides
    Last Post: 12th Feb 2012, 04:19
  2. HOW-TO - CONVERT AVI, OGM or MKV to DVD
    By Ecko_Blue in forum User guides
    Last Post: 19th Sep 2008, 10:10
  3. mencoder, convert mkv to avi + ac3. sound issues
    By clavain in forum Video Conversion
    Last Post: 29th Jan 2008, 18:02
  4. is there an easy wasy to convert ogm,mkv to avi or mpeg
    By nikkio3000 in forum Video Conversion
    Last Post: 17th May 2006, 11:53
  5. How to convert s/vcd, avi, ogm, mkv to dvd
    By boco_345 in forum User guides
    Last Post: 21st Oct 2004, 09:42
About   Advertise   Forum   RSS Feeds   Statistics   Tools
