I have yet been able to rip a good backup of an Arccos (sp?) disk with MTR, does anyone have any suggestion or settings that will work. I have tried The Grudge and Resident Evil Apocolypse, they get half way through or so and then it says "although the rip is complete there were bad sectors..."
Any help, thanks!!
Thread: Help with Arccos Disks
Try the MTR forum.
PLEASE DO A SEARCH IN THIS FORUM!
Ronin and I have figured this out and the results can be found easily right here.
Search: terryj+ronin
or search: terryj+the forgotten
the answers are here, you just need to learn to use the Search the Forum function."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
It also warns you that the disc might not play , and ( here are the key words ) check it before burning....
Well not to wory ... the newt version of MTR is ( at long last ) getting near to completion.....
not long now.
geezerbuttz
Help with Panasonic BD-RE Disks
By lee_leses in forum Blu-ray RippingReplies: 0Last Post: 23rd Aug 2010, 00:48 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
Statistics
Newest guides
Latest tool updates
New media comments
