VideoHelp.com Forum
  1. Member BrainStorm69's Avatar
    I have seen claims that this piece of equipment has a full frame TBC (as well as being a video mixer), but have not been able to find any "official" specs to that effect. Anyone know for sure?
    How old is it?
    The word "TBC" gets tossed around like candy these days, and is very often entirely incorrect.
  3. Some video mixers have dual TBC/Frame Sync in them. Their purpose is to allow smooth transitions from one video source to another (like two VCR's, a VCR and a video camera, etc.) Without genlocked TBC/Frame Sync on each source, you wind up with jumpy, glitchy edits.
    I had one of those and sold it some 5 years ago - changed to computer editing
    this Panasonic mixing table was a fine piece of equipment - fade in and fade out, mixing sources - adding titels etc... etc...
    you could even use it to eliminate macrovision from commercial tapes but the latter is not recommendable: it tended to ruin the internal power unit after a couple of macrovision protected tapes
    Here is the answer:
    All of the Panasonic WJ-****series have built in DFS and it is written on the face of most of those models but I can assure you when I first wanted a WJ-AVE5 I confirmed it with the sales rep (central audio visual, orlando, FL, usa) and his response was what I just told you.
    With a Digital Frame Synchronizer there is no need for the TBC component as one performs the function of synchronizing simultaneous inputs through digital conversion (using a RAMDAC) and then using a simple algorithm to generate the bitmap at each point of the fade/wipe/dissolve transfer (and adds cool features like mosaic, chroma and luminescence keying, paint, etc) and the other - Time Base Corrector essentially performs the function maintaining the analog signal - Panasonic's Digital Frame Synchronizer is what makes their products so appealing.
    Yes the WJ-AVE5 does have a DFS just like any of the WJ-MX10, MX12, MX50s, etc - we used a JVC unit with a seperate TBC and the crappy part about having a time base corrector is that they dont come with wipes or even basic FX - those are additional add on units making panasonic the very best buys as its DFS includes those however I would not suggest the mx 50 due to its price tag only resulting in a ton of wipe patterns and inputs - a good proucer/director only needs 2 inputs and perhaps a switchbox hooked onto one for plenty of connections.
    i LOVE the Panasonic WJ- series - I borrowed an ollld WJ-3500 from my high school and it actually had direct video camera support but only 17 wipe patterns but I was 13 and boy did i have fun with it!
    Ray Here is the answer:
    Ray
  1. Panasonic AG-7500 - does it have TBC?
    By Gibson's Squares in forum Restoration
    Last Post: 8th Apr 2011, 22:35
  2. Replies: 8
    Last Post: 15th Jan 2011, 09:43
  3. Replies: 16
    Last Post: 24th Mar 2010, 01:36
  4. Replies: 6
    Last Post: 22nd Nov 2007, 11:58
  5. panasonic VCR tbc + external tbc - any use ?
    By abbymat in forum Restoration
    Last Post: 15th Aug 2007, 08:29
