So I just installed Win XP Pro and I want to keep my system as clean as possible... that means not installing tons of codecs!!
What do you guys recommend for my MPEG2 codec... I need to be able to watch MPEG 2 videos and encode SVCD/DVD with TMPGENC.
It doesn't have to be free, I don't mind paying a little for a codec that is clean, good quality and trouble-free!
Any other suggestions you might have on codecs I should and should not install is appreciated. So far I'm only installed Xvid and Divx.
Thanks!
I installed the panasonic codec on my windows xp pro pc and so far no problems.
For MPEG-2, I usually just install PowerDVD and use the codec from it. I beleive even if you uninstall the program, the codec remains. For a free MPEG-2 codec, try Stinkys MPEG2 Codec.
Media Player Classic is a free alternative
Media Player Classic for sure!
No need for codecs. Plus, if you encode your videos to elemental streams (m2v + ac3) with the same name (video.m2v + video.ac3), you can just drag the video.m2v into Media Player Classic and it will also pickup the audio and play it.
vdub - bad PCM audio capture after fresh install of huffyuv
By wolfdogg in forum Video ConversionReplies: 1Last Post: 11th May 2011, 00:45 -
Trying to Install Microsoft MPEG-4 Video Codec V1, V2, V3
By eon_designs in forum Video ConversionReplies: 2Last Post: 10th May 2010, 13:03 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Codecs - Which to install on fresh OS?
By acommuter in forum Newbie / General discussionsReplies: 9Last Post: 7th Jul 2007, 16:39 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 18:01
