VideoHelp.com Forum
Results 1 to 14 of 14
    Hi,
    I got some tv episodes in mpg (vcd) format. I burned them on DVD+R and play them in my dvp 642. But after a few minutes the sound becomes out of sync. Why is that? I try the regular trick of pushing the Menu Button a few times to reset the sound, but it never syncs back completely. It's really annoying...
    The fsound is fine on my computer.
    Any idea?
    DrJOnes666
    It could be your media. Maybe a different brand of DVD+R would give better results. Also, you didn't say what kind of disc you burned. Did you burn raw MPG files to the DVD+R disc in DVD-ROM mode? Did you use another, unnamed, program to convert your files to DVD format and burn a DVD? When you say the sound is fine on your computer, do you mean on the original files or on the DVD you burned?
    Are you sure the audio in the mpeg files is in sync? If these mpeg files have been cut or trimmed by software that is not mpeg frame accurate then they could easily be out of sync more and more as you get further into the video. Also if the mpeg file was authored at a different audio bitrate than the original recording audio sync will gradually get worse as you play the video.
    bits
    Thanks for your input guys.
    The MPG files appear to have correct audio sync when I play them in WinXP using Windows Media Player.
    I burned the MPG files directly as-is on a DVD+R disc. I didn't convert them. When I load the disc in the 642, in the menu it shows a MPG VCD ICON beside each title track. I play them directly...
    Any idea if I should be indeed converting them or something?
    Do you really think that burning to another media would solve the problem? And if so, why would the media be the sourec of the out of sync problem?
    Thanks!
    DrJOnes666
  5. Member Krispy Kritter's Avatar
    When you play them on the computer...are you playing the originals or from the dvd you burned?
    Google is your Friend
  6. Member canadateck's Avatar
    I have Played every kind of DVD/CD on this player and the type that gives the most problems I find are VCD raw Mpeg files,Try burnung it as a VCD on the DVD then play it,I bet all the sync problems will be gone.
  7. Member canadateck's Avatar
    Thanks!
    DrJOnes666
    No this wont help
    I will try that and come back to let you guys know how it went.
    Thanks for the suggestion!
    DrJOnes666
    Does anyone know how I can create a VCD on a DVD-R disc?
    I'm trying to do it with Nero, but it seems to want to do it only with a CD-R and does not offer me the possibility of doing it on a DVD-R .
    damnit, it's complicated for no reason. I mean, the damn player should be able to play the mpg file without any problem!
  11. Member canadateck's Avatar
    what software do you have? you can drop the MPG into ulead and make a DVD, it wont re-encode the file/
  12. Member canadateck's Avatar
    With this Hobby you will always find problems.
  1. Philips DVP-642 16:9 Display
    By wulf109 in forum DVD & Blu-ray Writers
    Last Post: 27th Jan 2010, 12:39
  2. Philips dvp 642 help?
    By imemine in forum DVD & Blu-ray Players
    Last Post: 3rd Feb 2009, 02:22
  3. Philips DVP 5140 or DVP 642/37, which is better?
    By Amuse in forum DVD & Blu-ray Players
    Last Post: 2nd Feb 2008, 16:26
  4. Philips DVP-642 and x.264 HD encoding
    By dfishman923 in forum Newbie / General discussions
    Last Post: 13th May 2007, 14:36
