I have an internal DVD writer (Verbatim). LSS... I want to make it external.
Has anyone tried the IDE to USB cables?
Don't give in to DVD2ONE, that leads to the dark side.
Is this what you mean? http://www.dansdata.com/rdriver.htm.
It's an interesting idea. I can think of times when I might want to test or use a bare drive without opening up the computer case to connect it.
Apparently they have a similar circuit board in the IDE connector end that a USB external box has. Now that I've looked on the web, I see several different models.
buy one of these, they work wonders:
http://www.newegg.com/Product/Produc...82E16817145314
Here's a good thread
http://www.videohelp.com/forum/viewt...003172#1003172 (picture is a link)
BTW, I would go with Firewire over USB
http://www.videohelp.com/forum/viewtopic.php?t=234767
From the Videohelp Glossary:
Firewire-400 Mbs
USB-480 Mbps
That sounds missleading. USB is faster.Don't give in to DVD2ONE, that leads to the dark side.
It does sound misleading, but USB has a higher signalling and CPU overhead than Firewire. So firewire is just as fast and uses less of the CPU allowing for more reliable continuous transfers.Originally Posted by Marco33There are 10 kinds of people in this world. Those that understand binary...
I guess one of these in firewire would be best.
EDIT:
This one
http://www.newegg.com/Product/Produc...82E16817186007Don't give in to DVD2ONE, that leads to the dark side.
I bought one from CompUSA.
It has Firewire and USB. Installed with no software, works without a hitch.
$60 USDon't give in to DVD2ONE, that leads to the dark side.
Memorex 530vL Internal DVD Writer won't play dvd's, help!
By butche106 in forum DVD & Blu-ray WritersReplies: 2Last Post: 14th Feb 2012, 02:34 -
Write Error with Internal DVD Writer
By Soviani in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Oct 2009, 00:50 -
External/Internal dVD-R dual layer burner
By SIRCOOKS in forum ComputerReplies: 6Last Post: 14th May 2008, 11:45 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 17:12 -
Do internal/external DVD burners have copy protection built in?
By waldothewonderboy in forum Newbie / General discussionsReplies: 5Last Post: 21st Jul 2007, 23:01
