I have some small files, converted from Avi to DVD using VSO Divx To DVD. No problems. I have then tried to merge the files using DVTool ...fine, except they are all merged into a VIDEO_TS.BUP file.
How do I burn the merged file....NERO wants to see a VIDEO_TS file ?
Any help m8's ??
use tmpgenc dvd author, select add video and select the folder with the vob files.
you can also use dvdshrink, http://www.dvd-guides.com/content/view/46/59/ -
@ Baldrick
Many thanks for the tip. I didn't know Shrink would merge files in this way. Just tried it and it works !!
You're a star
Have DVD Files, need to merge subtitles into MPEG
By geekfemme in forum Video ConversionReplies: 3Last Post: 2nd Mar 2011, 19:07 -
Merge video files in DVD Flick?
By morgle in forum EditingReplies: 6Last Post: 13th Aug 2010, 10:28 -
Any software (free) can merge multiple MPEG files into one DVD title?
By csh in forum Authoring (DVD)Replies: 3Last Post: 15th May 2009, 01:17 -
How can I merge two video files into one?
By DVDNewb in forum Newbie / General discussionsReplies: 24Last Post: 17th Mar 2008, 13:58 -
how to merge two .mpg movie files into one dvd file
By morefeus46 in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2007, 19:43
