i want to rip a dvd that has episodes on it,not like an entire movie.
whats the best way to do it? so i can fit all episodes on 1 disk as data cd or vcd.
easiest/simplest way pls n ty
Thread: about rippin...
http://www.videohelp.com/forum/viewtopic.php?p=883991
http://www.videohelp.com/forum/viewtopic.php?p=883972
Dvd2one full disk
or
Dvdshrink
**EDIT**
Just noticed that you were looking to vcd so this may not be what your looking for....sorry[/b]What We Do In Life, Echoes In Eternity....
IMO the easiest/simplest way is to use EazyVCD - all you need to do is select each episode in turn (they will show up as separate titles) and then set your options, and it will handle the rest, outputting a VCD-compliant MPEG at the end.
... or if you want to do something different than VCD, just use smartripper in Movie Mode or DVDDecrypter in IFO Mode.If in doubt, Google it.
well ive tried ripping an episode dvd to vcd using EAZYVCD...but when ya go ta rip it, it only rips the 1st episode...how or whats the easiest thing ta use ta rip episodes so that they ALL fit on a vcd OR just your regular data cd
All eps won't fit on a VCD unless your eps are only a total of 80 minutes in length or less, or you do XVCD, in which case you'd be taking a serious quality hit IMO to fit any more than 80 minutes on. Or you could dump maybe 4 x 22 minute episodes on a Data CD as DivX or XviD.
I've got a DivX and XviD capable settop DVD player, and I use a batch file to rip all episodes to my HDD using DVDDecrypter in commandline mode. I then use autogk's batch function to set all the eps up, then leave it overnight to encode them all for me. Works really well with TV show season sets and stuff like that.
Here's a sample batch file:
This assumes that all episodes are in VTS_1, and are PGCs 1-4. I use IFOEdit to check that this is so.Code:"c:\program files\dvd decrypter\dvddecrypter.exe" /MODE IFO /SRC F: /DEST "D:\RIPPED\Episode 1\" /VTS 1 /PGC 1 /SPLIT NONE /START /CLOSE "c:\program files\dvd decrypter\dvddecrypter.exe" /MODE IFO /SRC F: /DEST "D:\RIPPED\Episdoe 2\" /VTS 1 /PGC 2 /SPLIT NONE /START /CLOSE "c:\program files\dvd decrypter\dvddecrypter.exe" /MODE IFO /SRC F: /DEST "D:\RIPPED\Episode 3\" /VTS 1 /PGC 3 /SPLIT NONE /START /CLOSE "c:\program files\dvd decrypter\dvddecrypter.exe" /MODE IFO /SRC F: /DEST "D:\RIPPED\Episode 4\" /VTS 1 /PGC 4 /SPLIT NONE /START /CLOSE
TV capturing n Rippin using VduB
By SMChoice in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2009, 10:39 -
audio rippin question
By completetech in forum AudioReplies: 2Last Post: 5th Apr 2009, 09:04
