i bought staples cd label paper and want to know what cover/label software i can use to format it and print it cuz i have coverxp and it doesnt have the format for the staples brand cd label.
Thread: cd/dvd cover label software?
If you plan to use these labels on dvd, don't. It will screw them up.
that is just a theory about screwing them up. ive done loads and never had problems.p.s you could try covermagic get it from here
http://newnet.unixthemes.tucows.com/...lcreators.html
It isn't a theory; it just isn't a problem under all circumstances. If you have great media, great burner, and a great player, you may not have problems. But if you let someone borrow your disk that has a less than great burner, then it may not play with a label. A simple test even under the best circumstances is to do a scan before and after applying the label. I have some media that will play with a label on my player, but will not play on my sister's. Some media will not play on anything. (with labels)
Do not label DVDs.
If you REALLY need pretty pictures on top,
buy inkjet media and get a CD/DVD printer.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Free DVD cover/Label download sites?
By SilverBlade in forum MediaReplies: 13Last Post: 6th Aug 2011, 11:34 -
Good lightscribe label software
By neworldman in forum Newbie / General discussionsReplies: 10Last Post: 28th Mar 2010, 12:48 -
DVD cover software
By Prot in forum MediaReplies: 6Last Post: 3rd May 2009, 23:38 -
cover & label?
By ptr866 in forum MediaReplies: 2Last Post: 27th Feb 2008, 07:37
